TargetDefinitionGenerator usage [message #1444760] |
Tue, 14 October 2014 14:12 |
Abel Hegedus Messages: 197 Registered: September 2015 |
I have managed to get the TargetDefiitionGenerator to work, in that by adding the annotation to the Targlet task, it generates a .target file upon performing it.
<annotation
source="http:/www.eclipse.org/oomph/targlets/TargetDefinitionGenerator">
<detail key="location"><value>${git.clone.location/releng/mytarget.target}</value></detail>
<detail key="includeAllPlatforms"><value>false</value></detail>
<detail key="includeSource"><value>false</value></detail>
<detail key="generateVersions"><value>true</value></detail>
</annotation>
1. I found that the File _must_ exist, otherwise the generation fails (although gracefully, a status is added to the Error log). Bug or feature?
2. I added "generateVersions" since the target is stupid, and without this, Tycho fails to find the correct versions.
3. The generated target only contains requirements from the Targlet where the annotation is added. This is understandable, however, I wanted to have two Targlets, as I saw in other setups in the catalog. However, this means that the generated target will not contain the required features from the other Targlets.
4. Simply adding the same repositories to the Targlet (without adding additional dependencies) seems to work.
5. Note that there may be some requirements that are not needed in the Targlet directly, but are needed in the .target for correct building (e.g. xbase.lib), I circumvented this by adding xtext.sdk requirement directly.
In the end, I managed to solve all my issues, another victory for Oomph
Re: TargetDefinitionGenerator usage [message #1444764 is a reply to message #1444760] |
Tue, 14 October 2014 14:19 |
Ed Merks Messages: 33142 Registered: July 2009 |
Abel,
Comments below.
> upon performing it.
> <annotation
> <detail
> </annotation>
> feature?
I think it's a bug that we of course don't notice once it exists...
Please open bugzilla.
Yes, we generate one for Oomph purely for our Tycho builds.
Targlets are composed into a single target definition. In fact we have
a bit of a problem that the generated TP contains things we don't want
from the extra projects materialized by the other targlets...
I'm not sure I completely understand the setup involved.
> directly.
Yes, we often want extra things so that they'll be available in the
launched IDE, even if not directly required by the projects in the
workspace...
> Oomph :)
Cool. :-)
Ed Merks
FUDForum. Page generated in 0.03877 seconds
