Home » Newcomers » Newcomers » [Luna] mysterious workspace loaded at first startup
[Luna] mysterious workspace loaded at first startup [message #1444031] |
Mon, 13 October 2014 14:58 |
Simone Perriello Messages: 25 Registered: October 2014 |
I don't know why, but now, when I launch eclipse, it shows a workspace with no projects in it. So, to change workspace, I've to manually select the right one via menu.
This anonymous workspace points to the home: any new project is automatically added to the home folder. It is shown only on the startup.
I tried to see the list of workspaces in Windows>Preferences>General>Startup and Shutdown>Workspaces; no sign of this new workspace.
I aso tried to edit the .../eclipse/configuration/.settings/org.eclipse.ui.ide.prefs file, but again no sign of the home workspace.
Even if, from other workspaces, I select File>Switch Workspace, there is no sign of it; instead, from this "anonymous" workspace, if I select File>Switch Workspace, it shows ALL the workspaces.
Also the "Prompt for workspace on startup" option doesn't work.
What's going on?
Re: [Luna] mysterious workspace loaded at first startup [message #1445664 is a reply to message #1445610] |
Wed, 15 October 2014 19:19 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Hmm, very strange. One more triple-check:
Open the About Eclipse dialog and click the Installation Details button. The go to the Configuration tab. Once the data loads, look for eclipse.home.location and tell what the value is.
Actually, you could paste in the whole first part of that Configuration data, up until the *** Features line. Maybe something in there will give a clue as to what's going on.
[Updated on: Wed, 15 October 2014 19:20] Report message to a moderator
Re: [Luna] mysterious workspace loaded at first startup [message #1445685 is a reply to message #1445664] |
Wed, 15 October 2014 20:04 |
Eric Rizzo wrote on Wed, 15 October 2014 19:19...
*** Date: Wednesday, October 15, 2014 at 10:00:37 PM Central European Summer Time
*** Platform Details:
*** System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.X11.XToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=4.4.1.M20140925-0400
eclipse.commands=-data
/media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva
-os
linux
-ws
gtk
-arch
x86_64
-showsplash
/opt/eclipse//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
-launcher
/opt/eclipse/eclipse
-name
Eclipse
--launcher.library
/opt/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140603-1326/eclipse_1605.so
-startup
/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.appendVmargs
-exitdata
2e8018
-product
org.eclipse.epp.package.jee.product
-vm
/usr/bin/java
eclipse.home.location=file:/opt/eclipse/
eclipse.launcher=/opt/eclipse/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.startTime=1413385294028
eclipse.stateSaveDelayInterval=30000
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.6
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
-jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
gosh.args=--nointeractive
guice.disable.misplaced.annotation.check=true
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
java.class.version=52.0
java.endorsed.dirs=/usr/lib/jvm/java-8-oracle/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-8-oracle/jre/lib/ext:/usr/java/packages/lib/ext
java.home=/usr/lib/jvm/java-8-oracle/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.8.0_20-b26
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.8
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.8.0_20
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.8
java.vm.vendor=Oracle Corporation
java.vm.version=25.20-b23
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=/opt/eclipse//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.m2e.log.dir=/media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva/.metadata/.plugins/org.eclipse.m2e.logback.configuration
org.eclipse.swt.browser.DefaultType=mozilla
org.eclipse.swt.browser.MozillaFactoriesRegistered=true
org.eclipse.swt.browser.XULRunnerInitialized=true
org.eclipse.swt.browser.XULRunnerPath=/opt/eclipse/plugins/org.mozilla.xulrunner.gtk.linux.x86_64_1.9.2.19pre/xulrunner
org.eclipse.swt.internal.gtk.useCairo=true
org.eclipse.update.reconcile=false
org.jboss.tools.resolved.remote.properties=examples.categories.url|jbosstools|4.2=http://download.jboss.org/jbosstools/examples/project-examples-category-4.2.xml
maven.examples.url|jbosstools|4.2=http://download.jboss.org/jbosstools/examples/project-examples-maven-4.2.GA.xml
jboss.discovery.site.url|jbosstools|4.2.0=http://download.jboss.org/jbosstools/updates/development/luna/central/core/
jboss.discovery.directory.url|jbosstools|4.2.0=http://download.jboss.org/jbosstools/updates/development/luna/jbosstools-directory.xml
buzz.feed.url=http://planet.jboss.org/feeds/buzz
jboss.discovery.earlyaccess.list.url|jbosstools|4.2.0=http://download.jboss.org/jbosstools/updates/development/luna/jbosstools-earlyaccess.properties
jboss.discovery.earlyaccess.site.url|jbosstools|4.2.0=http://download.jboss.org/jbosstools/earlyaccess/development/luna/
community.examples.url|jbosstools|4.2=http://download.jboss.org/jbosstools/examples/project-examples-community-4.2.Beta2.xml
portal.examples.url|jbosstools|4.2=http://download.jboss.org/gatein/quickstarts/jboss-portal-6.2/project-examples-jboss-portal6.2-jbds8.0-001.xml
featured.examples.url|jbosstools|4.2=http://download.jboss.org/jbosstools/examples/project-examples-shared-4.2.GA.xml
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JavaSE/compact1-1.8,JavaSE/compact2-1.8,JavaSE/compact3-1.8,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7,JavaSE-1.8
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=3.13.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8",osgi.ee; osgi.ee="JavaSE/compact1"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact2"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact3"; version:List<Version>="1.8"
org.osgi.framework.system.packages=<...content trimmed...>
org.osgi.framework.uuid=2028c027-7c54-0014-1f28-9b8978f7b73a
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Linux
os.version=3.13.0-37-generic
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar,reference:file:org.eclipse.fx.osgi_1.0.0.201408250501.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/opt/eclipse/configuration/
osgi.configuration.area.default=null
osgi.framework=file:/opt/eclipse/plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar,reference:file:org.eclipse.fx.osgi_1.0.0.201408250501.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:/opt/eclipse/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar, file:/opt/eclipse/plugins/org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar, file:/opt/eclipse/plugins/org.eclipse.fx.osgi_1.0.0.201408250501.jar
osgi.install.area=file:/opt/eclipse/
osgi.instance.area=file:/media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva/
osgi.instance.area.default=file:/home/xxx/
osgi.logfile=/media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva/.metadata/.log
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/opt/eclipse//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse/plugins
osgi.tracefile=/media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva/.metadata/trace.log
osgi.user.area=file:/home/xxx/user/
osgi.user.area.default=null
osgi.ws=gtk
path.separator=:
product.home=/opt/eclipse/plugins/org.jboss.tools.common.model_3.6.0.CR1-v20140829-2038-B51/
securerandom.source=file:/dev/./urandom
sun.arch.data.model=64
sun.boot.class.path=/usr/lib/jvm/java-8-oracle/jre/lib/resources.jar:/usr/lib/jvm/java-8-oracle/jre/lib/rt.jar:/usr/lib/jvm/java-8-oracle/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-8-oracle/jre/lib/jsse.jar:/usr/lib/jvm/java-8-oracle/jre/lib/jce.jar:/usr/lib/jvm/java-8-oracle/jre/lib/charsets.jar:/usr/lib/jvm/java-8-oracle/jre/lib/jfr.jar:/usr/lib/jvm/java-8-oracle/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-8-oracle/jre/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.font.fontmanager=sun.awt.X11FontManager
sun.io.unicode.encoding=UnicodeLittle
sun.java.command=/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar -data /media/Data/Personal Folder/Programming/Eclipse/ComputazionePervasiva -os linux -ws gtk -arch x86_64 -showsplash /opt/eclipse//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp -launcher /opt/eclipse/eclipse -name Eclipse --launcher.library /opt/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140603-1326/eclipse_1605.so -startup /opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar --launcher.appendVmargs -exitdata 2e8018 -product org.eclipse.epp.package.jee.product -vm /usr/bin/java -vmargs -Dosgi.requiredJavaVersion=1.6 -XX:MaxPermSize=256m -Xms40m -Xmx512m -jar /opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
sun.os.patch.level=unknown
user.country=US
user.dir=/home/xxx
user.home=/home/xxx
user.language=en
user.name=xxx
user.timezone=Europe/Rome
[Updated on: Thu, 16 October 2014 12:45] by Moderator Report message to a moderator
Re: [Luna] mysterious workspace loaded at first startup [message #1446186 is a reply to message #1446172] |
Thu, 16 October 2014 13:20 |
Eric Rizzo wrote on Thu, 16 October 2014 13:03What you're saying and what what the evidence says (the configuration details you posted) are two different things. Which is it?
Evidence is that I normally launch eclipse via terminal
cd /opt/eclipse
./eclipse
or via an icon launcher, in both cases without any further command. Btw, after reading again the details, I think tjat maybe the problem is related with the equinox launcher. Not sure about that tbh.
$>./eclipse
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
org.eclipse.m2e.logback.configuration: The org.eclipse.m2e.logback.configuration bundle was activated before the state location was initialized. Will retry after the state location is initialized.
org.eclipse.m2e.logback.configuration: Logback config file: /opt/eclipse/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.5.0.20140606-0033.xml
org.eclipse.m2e.logback.configuration: SLF4J logger factory class: org.slf4j.helpers.SubstituteLoggerFactory
org.eclipse.m2e.logback.configuration: Initializing logback
java.lang.ClassCastException: org.eclipse.osgi.internal.framework.EquinoxConfiguration$1 cannot be cast to java.lang.String
at org.eclipse.m2e.logback.configuration.LogHelper.logJavaProperties(LogHelper.java:26)
at org.eclipse.m2e.logback.configuration.LogPlugin.loadConfiguration(LogPlugin.java:189)
at org.eclipse.m2e.logback.configuration.LogPlugin.configureLogback(LogPlugin.java:144)
at org.eclipse.m2e.logback.configuration.LogPlugin.access$2(LogPlugin.java:107)
at org.eclipse.m2e.logback.configuration.LogPlugin$1.run(LogPlugin.java:62)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
[INFO] Setting property: classpath.resource.loader.class => 'org.codehaus.plexus.velocity.ContextClassLoaderResourceLoader'.
[INFO] Setting property: velocimacro.messages.on => 'false'.
[INFO] Setting property: resource.loader => 'classpath'.
[INFO] Setting property: resource.manager.logwhenfound => 'false'.
log4j:WARN No appenders could be found for logger (org.springsource.ide.eclipse.commons.core.templates.TemplateProcessor).
log4j:WARN Please initialize the log4j system properly.
There is also a bug opened for this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=445122
[Updated on: Thu, 16 October 2014 13:23] Report message to a moderator
Re: [Luna] mysterious workspace loaded at first startup [message #1448322 is a reply to message #1446186] |
Sun, 19 October 2014 19:45 |
Another update. The previous configuration (Installation Details> Configuration) was loaded when I've yet loaded the target workspace. Instead, this shown below is the same output taken from the mysterious workspace. Hope this help.
*** Date: Sunday, October 19, 2014 at 9:37:59 PM Central European Summer Time
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-showsplash
-launcher
-name
Eclipse
--launcher.library
-startup
-exitdata
4064800c
-product
-vm
/usr/bin/java
eclipse.startTime=1413747456898
-Xms40m
-Xmx512m
-jar
equinox.use.ds=true
file.encoding=UTF-8
file.separator=/
java.io.tmpdir=/tmp
java.library.path=/usr/lib/nvidia-331/:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.runtime.version=1.8.0_25-b17
java.version=1.8.0_25
java.vm.version=25.25-b02
line.separator=
org.eclipse.m2e.log.dir=/home/xxx/.metadata/.plugins/org.eclipse.m2e.logback.configuration
org.eclipse.update.resolution_url=
org.osgi.framework.system.packages=<content truncated>
org.osgi.framework.uuid=402fed61-c757-0014-1f16-ed19c45e2914
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar,reference:file:org.eclipse.fx.osgi_1.0.0.201408150502.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar,reference:file:org.eclipse.fx.osgi_1.0.0.201408150502.jar
osgi.frameworkClassPath=., file:/opt/eclipse/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar, file:/opt/eclipse/plugins/org.eclipse.equinox.weaving.hook_1.1.100.weaving-hook-20140821.jar, file:/opt/eclipse/plugins/org.eclipse.fx.osgi_1.0.0.201408150502.jar
osgi.instance.area=file:/home/xxx/
osgi.logfile=/home/xxx/.metadata/.log
osgi.nl=en_US
osgi.os=linux
osgi.tracefile=/home/xxx/.metadata/trace.log
osgi.user.area=null
osgi.ws=gtk
path.separator=:
sun.cpu.isalist=
sun.desktop=gnome
sun.java.command=/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar -os linux -ws gtk -arch x86_64 -showsplash /opt/eclipse//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp -launcher /opt/eclipse/eclipse -name Eclipse --launcher.library /opt/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140603-1326/eclipse_1605.so -startup /opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar --launcher.appendVmargs -exitdata 4064800c -product org.eclipse.epp.package.jee.product -vm /usr/bin/java -vmargs -Dosgi.requiredJavaVersion=1.6 -XX:MaxPermSize=256m -Xms40m -Xmx512m -jar /opt/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
user.country=US
user.dir=/home/xxx
user.home=/home/xxx
user.language=en
user.name=xxx
[Updated on: Mon, 20 October 2014 13:46] by Moderator Report message to a moderator
Re: [Luna] mysterious workspace loaded at first startup [message #1448831 is a reply to message #1448819] |
Mon, 20 October 2014 14:02 |
Eric Rizzo wrote on Mon, 20 October 2014 13:46It's not clear what you're trying now. The configuration details above do not include the -data option that loads a specific workspace; the info suggests that it was running on a workspace at /home/xxx/
Can you be more specific and detailed about what you're doing when you post these details, and what behavior you're observing?
Sure.
I'll post a short summary.
These are the steps that now I'm forcing to execute in order to have a working workspace:
- I launch eclipse (without any further options)
- -----it shows the anonymous workspace (no projects and so on)
- I switch workspace File>Switch workspace>WhateverWorkspace
- -----it shows the WhateverWorkspace
Now, if I click on File>Switch workspace there is no track of the anonymous workspace. However, if, after step 2, I create a new project, this is created in the home directory. So, the anonymous workspace points to my home and I don't know why.
Regarding the configuration details, the first one that I posted are taken from step 4 (so when I'm working on the WhateverWorkspace), while the second ones are taken from step 2 (so when I'm working on the anonymous workspace).
Hope this helps a little bit more.
[Updated on: Mon, 20 October 2014 15:45] Report message to a moderator
Current Time: Fri Apr 26 07:43:39 GMT 2024
Powered by FUDForum. Page generated in 0.10986 seconds
