Home » Eclipse Projects » Babel » Babel Pseudo Translation Test:
Re: Babel Pseudo Translation Test: [message #25503 is a reply to message #25463] |
Sat, 14 March 2009 06:36 |
Originally posted by: atoulme.intalio.com
Elena Nayashkova wrote:
> I'd like to run Babel Pseudo Translation Test on Memory Analyzer
> (technology.mat) to verify its translatablity, but the pseudo
> translation language packs are not generated yet (In fact there was no
> translation for MAT at all so far). Does Babel provide a tool to
> generate those pseudo packs?
> Best Regards,
> Elena.
Hey Elena, nice to have you on the webinar this week. We had a big bug
with the new strings and that should be resolved over the weekend.
What also might happen is that hte map file you provided isn't giving
anything, ie there is a problem with it.
In any case, I would rather discuss this through a bug. Please open one,
I will check your map file meanwhile.
Re: Babel Pseudo Translation Test: [message #25621 is a reply to message #25503] |
Sat, 14 March 2009 07:18 |
>> Hi,
>> Best Regards,
>> Elena.
I just checked your map file and there is something wrong with it indeed
(and I know you copied it from stp.bpmn, and yes I just corrected it for
that project too, sorry!)
Your plugin reference looks like this:
plugin@org.eclipse.mat.api= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.mat,,trunk/plugins/org.eclipse.mat.api
instead, change it to look like this:
plugin@org.eclipse.mat.api= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.mat,,plugins/org.eclipse.mat.api
We now read the trunk part as the second fragment, so there is no more
need to output trunk/plugins/org.eclipse.mat.api,
plugins/org.eclipse.mat.api is enough.
Antoine
Re: Babel Pseudo Translation Test: [message #25867 is a reply to message #25463] |
Tue, 17 March 2009 11:44 |
I opened a bug for you:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268949
Antoine
> Best Regards,
> Elena.
Re: Babel Pseudo Translation Test: [message #26354 is a reply to message #26234] |
Thu, 02 April 2009 20:38 |
> Thanks Antoine, I've just fixed it. If the map file is correct the
> pseudo translation package should be generated over the weekend, right?
> Regards,
> Elena.
Yes. The server is down so this might take a bit longer.
Re: Babel Pseudo Translation Test: [message #577312 is a reply to message #25463] |
> Best Regards,
> Elena.
Re: Babel Pseudo Translation Test: [message #577382 is a reply to message #25503] |
>> Hi,
>> Best Regards,
>> Elena.
Antoine
Re: Babel Pseudo Translation Test: [message #577482 is a reply to message #25463] |
Antoine
> Best Regards,
> Elena.
Re: Babel Pseudo Translation Test: [message #577833 is a reply to message #26234] |
> Regards,
> Elena.
Current Time: Sun Sep 22 22:00:44 GMT 2024
Powered by FUDForum. Page generated in 0.06281 seconds
