Home » Eclipse Projects » Eclipse Platform » Bug in Type Hierarchy w/ Filters
Bug in Type Hierarchy w/ Filters [message #257354] Thu, 01 July 2004 03:06 Go to next message
It appears that the filter settings aren't applied when I enter a Type
Hierarchy. I've set the filter in the Type Hierarchy to "On any resource in
same project" and it does indeed stay that way between successive openings of
the Type Hierarchy. However, when the Type Hierarchy comes up, it's still
showing (for instance) all of my Problems, not just the ones in this project.
If I then open the Filters and press OK, then I see just the ones I expect.
Is this the expected behaviour?
Re: Bug in Type Hierarchy w/ Filters [message #257362 is a reply to message #257354] Thu, 01 July 2004 03:10 Go to previous message
OK, I lie--if I select "On any resource in same project" the filters never seem
to match anything! I'd expect to only see Problems that are in the same project
as the current class. Am I missing something?
> resource in same project" and it does indeed stay that way between
> successive openings of the Type Hierarchy. However, when the Type
> Hierarchy comes up, it's still showing (for instance) all of my
> Problems, not just the ones in this project. If I then open the Filters
Previous Topic:using the plugin architecture
Next Topic:[Question] inner brackets-highlight / Scoping
Current Time: Wed Aug 20 18:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.06515 seconds
