Home » Language IDEs » Java Development Tools (JDT) » Generics and compiler Difference Eclipse vs javac
Generics and compiler Difference Eclipse vs javac [message #257143] Sun, 02 November 2008 03:39 Go to next message
I just discover something strange when trying to build one of my
projects with maven.
I have code like this:
-------->8--------
public BaseClass {
private String propertyA = "";
public <V extends Object> V getProperty(int propertyId) {
if( propertyId == 1 ) {
return (V) propertyA;
throw new IllegalArgumentException(
"Property with id '"+propertyId+"' unknown.");
public MyClass extends BaseClass {
private String propertyB = "";
public <V extends Object> V getProperty(int ) {
if( propertyId == 2 ) {
return (V) propertyB;
return super.getProperty(propertyId);
-------->8--------
This compiles fine in Eclipse but compiling with javac I get the
following error.
-------->8--------
type parameters of <V>V cannot be determined; no unique maximal instance
exists for type variable V with upper bounds V,java.lang.Object.
-------->8--------
To make it compile I had to change it like this:
-------->8--------
return (V) super.getProperty(propertyId);
-------->8--------
So it looks like the Eclipse Java Compiler is smarter than Javac but is
this really desired?
The javac I'm using is the one coming with OS-X 10.4 which is currently
javac 1.5.0_16.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Generics and compiler Difference Eclipse vs javac [message #257154 is a reply to message #257143] Mon, 03 November 2008 04:00 Go to previous message
If it were, it would not be the first case...
Try to have a look in Eclipse and/or Sun bug trackers: if there's a bug
report against javac already open, I think Eclipse Java Compiler is ok
and doesn't need to be changed. If there is not, I know about other
times in which EJC has been changed in order to be compatible with
javac, even if this went against the Java Language Specification.
Anyway, a JDT developer would certainly give you a better answer.
Mauro.
Previous Topic:the templates weren't work for me
Next Topic:How can I view Java bytecode in eclipse?
Current Time: Thu Oct 30 18:56:00 EDT 2025
Powered by FUDForum. Page generated in 0.24432 seconds
