| Export in Excel and Download a file [message #1440415] |
Wed, 08 October 2014 06:35  |
Hi all,
I have the need to export some data to Excel and I also the need to create a XML file, creating a file on the client pc.
How can I specify the destination folder in the RAP?
The RAP filechooser you can only upload files. Download is not possible as the javadoc says:
* Load or Save
* <ul>
* <li><code>true</code> loads the file from the file system into the application.</li>
* <li><code>false</code> saves the file from the application to the file system. Attention: This does not work in
* RAP/Web-UI</li>
* </ul>
Thanks in advance for any help
[Updated on: Wed, 08 October 2014 06:37] by Moderator
FUDForum. Page generated in 0.05039 seconds
