Re: [EMF Forms] Show Rule not working if condition is an Enum Feature [message #1440338 is a reply to message #1440255] |
Wed, 08 October 2014 08:26 |
Jonas Helming Messages: 699 Registered: July 2009 |
Enum is definitly supported, I would say 90% of the use cases are Enums.
I am not sure, what is wrong here, which version do you use?
Can you reproduce this with an example model?
Best regards
Jonas
Am 08.10.2014 08:00, schrieb Annamalai Chockalingam:
> Hi
> I have 2 Groups in a form. 1st group has a Enum Combo.
> Based on the value in the Combo, i need to decide to show or not show
> the 2nd Group.
> So on the 2nd Group, i created a Show Rule, Enabled the Rule and in the
> Leaf Condition i added the Feature Reference to the Enum Variable in my
> Model. then on the leaf condition if i click on select object to get the
> popup to mention the Enum Value, i see nothing really happening.
> therefore doubt if enum is supported in the Leaf Condition of Show Rule
> or Enable Rule. not sure if i am making a mistake. But if i put an
> integer or boolean as Feature Reference then Select Object is opening up
> the dialog.
> Regards
> Malai
FUDForum. Page generated in 0.03788 seconds
