Re: Resource Writable Query? [message #1439792 is a reply to message #1439107] |
Tue, 07 October 2014 14:12 |
Samuel Padgett Messages: 30 Registered: July 2009 |
Member |
Matt,
There might be a few ways, but it depends on the provider. If the provider has implemented HTTP OPTIONS, you could make an OPTIONS request on the URI to see if PUT is in the Allow header. This isn't required by the spec, however, and I suspect many providers haven't implemented OPTIONS. It also might not work if the resource is editable, but the user doesn't have the right authority.
It's possible the provider has its own property to indicate if the resource is read only, but there's no Core common property for it. There's an oslc:readOnly, but that's meant for resource shapes. I'd look at the resource RDF and see if there's anything in it you can use.
Good luck,
Sam
FUDForum. Page generated in 0.03613 seconds
