Home » Eclipse Projects » Eclipse Platform » Can't run Eclipse 3.0
| Can't run Eclipse 3.0 [message #255986] |
Sat, 26 June 2004 15:48  |
Originally posted by: spam6502.pacbell.net
--------------070401080302010607000509
Content-Type: text/plain; charset=us-ascii; format=flowed
This is on Windows XP pro, and SDK 1.4.2_04. Both eclipse and jdk are
installed to the root of c: (no spaces or illegal chars in the paths).
I get the dialog box "an error has occurred see the log file xxx.log"
(attached). I did a pretty thorough search and didn't find anything
applicable (I'm not updating an older installation, and one message with
a similar problem to mine hasn't been answered since February).
thanks,
Rob D
name="1088279162937.log"
Content-Disposition: inline;
filename="1088279162937.log"
!SESSION Jun 26, 2004 12:46:03.359 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_04
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.359
!MESSAGE Startup error
!STACK 1
java.lang.IllegalStateException: Bundle initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.0.0/ was not resolved.
at org.eclipse.core.runtime.adaptor.EclipseStarter.startBundles (EclipseStarter.java:824)
at org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:439)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!MESSAGE Bundle initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.0.0/ [152] was not resolved.
!MESSAGE Bundle initial@reference :file:c:/eclipse/plugins/org.eclipse.update.configurator_3.0 .0/ [153] was not resolved.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.375
!MESSAGE Bundle update@/c:/eclipse/plugins/org.apache.ant_1.5.3/ [154] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.375
!MESSAGE Missing required bundle org.apache.xerces_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.runtime.compatibility_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.runtime_2.1.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.apache.lucene_1.2.1/ [156] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.apache.xerces_4.0.13/ [158] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.core_2.1.3/ [159] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.core_3.0.0/ [160] was not resolved.
!MESSAGE Missing required bundle org.eclipse.core.variables_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.ui_3.0.0/ [161] was not resolved.
!MESSAGE Missing optionally required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.ui.views_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.jface.text_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.ui.workbench.texteditor_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.ui.editors_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ant.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.resources_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.filebuffers_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.externaltools_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui_0.0.0.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.390
!MESSAGE Missing required bundle org.eclipse.ui.console_0.0.0.
!MESSAGE Missing required bundle org.eclipse.debug.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.debug.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.launching_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.runtime_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.core_0.0.0.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.390
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.compare_2.1.0/ [162] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.compare_3.0.0/ [163] was not resolved.
!MESSAGE Missing required bundle org.eclipse.jface.text_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.views_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.boot_2.1.3/ [164] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.expressions_3.0. 0/ [166] was not resolved.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.406
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.filebuffers_3.0. 0/ [167] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.406
!MESSAGE Missing required bundle org.eclipse.text_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.resources.win32_ 2.1.0/ [168] was not resolved.
!MESSAGE Missing host org.eclipse.core.resources_[2.1.0,3.0.0].
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.resources.win32_ 3.0.0/ [169] was not resolved.
!MESSAGE Missing host org.eclipse.core.resources_[3.0.0,4.0.0).
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.resources_2.1.1/ [170] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.resources_3.0.0/ [171] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.runtime.compatib ility_3.0.0/ [172] was not resolved.
!MESSAGE Missing required bundle org.eclipse.update.configurator_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.runtime_2.1.1/ [173] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.421
!MESSAGE Missing required bundle org.apache.xerces_[4.0.13,4.1.0).
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.421
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.core.variables_3.0.0/ [175] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.core_2.1.2/ [176] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.core_3.0.0/ [177] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.ui_2.1.3/ [178] was not resolved.
!MESSAGE Missing required bundle org.eclipse.help_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.help.base_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.ui_3.0.0/ [179] was not resolved.
!MESSAGE Missing required bundle org.eclipse.core.expressions_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.editors_0.0.0.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.437
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.appserver_2.1.0/ [180] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.437
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.appserver_3.0.0/ [181] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.base_3.0.0/ [182] was not resolved.
!MESSAGE Missing required bundle org.eclipse.help.appserver_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.ide_3.0.0/ [183] was not resolved.
!MESSAGE Missing required bundle org.eclipse.help.base_0.0.0.
!MESSAGE Missing required bundle org.eclipse.help.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.search_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.ui.win32_2.1.0/ [184] was not resolved.
!MESSAGE Missing host org.eclipse.help.ui_[2.1.0,3.0.0].
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.ui_2.1.1/ [185] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.ui_3.0.0/ [186] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.453
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.453
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.webapp_2.1.3/ [187] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.webapp_3.0.0/ [188] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help_2.1.2/ [189] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help_3.0.0/ [190] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.core_2.1.3/ [191] was not resolved.
!MESSAGE Missing optionally required bundle org.eclipse.ant.core_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.team.core_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.core_3.0.0/ [192] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug.ui_2.1.1/ [193] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.468
!MESSAGE Missing required bundle org.eclipse.jdt.debug_0.0.0.
!MESSAGE Missing required bundle org.eclipse.compare_0.0.0.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.468
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug.ui_3.0.0/ [194] was not resolved.
!MESSAGE Missing required bundle org.eclipse.ltk.core.refactoring_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug_2.1.2/ [195] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug_3.0.0/ [196] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.doc.isv_2.1.0/ [197] was not resolved.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.484
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.doc.user_2.1.0/ [199] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.484
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.junit_2.1.1/ [202] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.junit_3.0.0/ [203] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.launching_2.1.1/ [204] was not resolved.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.500
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.launching_3.0.0/ [205] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.500
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.source_2.1.3/ [206] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.ui_2.1.3/ [208] was not resolved.
!MESSAGE Missing required bundle org.eclipse.team.core_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.ui_3.0.0/ [209] was not resolved.
!MESSAGE Missing required bundle org.eclipse.ltk.ui.refactoring_0.0.0.
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.515
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt_2.1.3/ [210] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.515
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt_3.0.0/ [211] was not resolved.
!MESSAGE Missing required bundle org.eclipse.ui.intro_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.cheatsheets_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jface.text_2.1.0/ [212] was not resolved.
!MESSAGE Missing required bundle org.eclipse.swt_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jface_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jface.text_3.0.0/ [213] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jface_2.1.3/ [214] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jface_3.0.0/ [215] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ltk.core.refactoring_ 3.0.0/ [216] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.531
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.531
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3. 0.0/ [217] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.build_2.1.3/ [221] was not resolved.
!MESSAGE Missing required bundle org.eclipse.update.core_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.build_3.0.0/ [222] was not resolved.
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility_0.0.0.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.core_2.1.2/ [223] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.core_3.0.0/ [224] was not resolved.
!SUBENTRY 1 org.eclipse.osgi Jun 26, 2004 12:46:03.546
!ENTRY org.eclipse.osgi Jun 26, 2004 12:46:03.546
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.doc.user_2.1.0/ [225] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.doc.user_3.0.0/ [226] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.runtime_2.1.0/ [228] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.runtime_3.0.0/ [229] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.source_2.1.3/ [230] was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.pde.ui_2.1.2/ [232] was not resolved.
| Re: Can't run Eclipse 3.0 [message #256076 is a reply to message #255986] |
Sun, 27 June 2004 10:40   |
Originally posted by: pascal.ibm.canada
From the content of your log, it seems that you have both 2.1 and 3.0
plugins in the same folder (for example:
c:/eclipse/plugins/org.eclipse.core.boot_2.1.3 and
c:/eclipse/plugins/org.eclipse.ant.ui_3.0.0/).
This is not a supported. Separate your eclipse install into two
different folders.
PaScaL
> thanks,
> Rob D
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
| Re: Can't run Eclipse 3.0 [message #256194 is a reply to message #256076] |
Sun, 27 June 2004 22:31  |
> different folders.
I deleted all the older .jar versions and it now works. Thanks!
Current Time: Wed Nov 05 19:58:43 EST 2025
Powered by FUDForum. Page generated in 0.04776 seconds
