Home » Newcomers » Newcomers » problems with ctrl-space
problems with ctrl-space [message #255880] Thu, 08 May 2008 11:08 Go to next message
I'm having problems with ctrl-space in my laptop. it doesn't work!!!! :-(
In others machines I have not any problems, but I can't use this basic
functionality in may laptop.
Any idea?
Thank you in advance.
Re: problems with ctrl-space [message #255882 is a reply to message #255880] Thu, 08 May 2008 12:32 Go to previous messageGo to next message
Any messages in the log? [workspace]/.metdata/.log
Wayne
On Thu, 2008-05-08 at 15:08 +0000, ro wrote:
> Any idea?
Re: problems with ctrl-space [message #255886 is a reply to message #255880] Thu, 08 May 2008 15:09 Go to previous messageGo to next message
Originally posted by: groups.pellaton.li
Some Notebooks use "weird" shortcuts for functions like screen
switching, undocking, screen zooming, ... Could it be that the
ctrl+space is already occupied by such a function?
You can check whether [ctrl]+[space] makes it through to Eclipse:
- select Window > Preferences
- search for Keys
- put the cursor into the field "Binding"
- hit [Ctrl]+[Space]
btw: I hate the notebook keyboards that have a [fn] key at the
lower left corner --> Being use to work with a normal keyboard,
I often hit [fn] instead of [Ctrl] when using my notebook undocked.
HTH
Michael Pellaton
Re: problems with ctrl-space [message #255913 is a reply to message #255880] Fri, 09 May 2008 04:56 Go to previous messageGo to next message
ro wrote:
Which editor? Can you explain what happens when you press Ctrl+Space.
Dani
> Any idea?
Re: problems with ctrl-space [message #255915 is a reply to message #255886] Fri, 09 May 2008 04:57 Go to previous messageGo to next message
I have checked the eclipse ctrl-space configuration and it is ok, I also
have connected an standard keyboard to my laptop with no success.
I have been looking the workspace .log but there is no new line when I
press ctrl-space.
any other idea?
thank you
Re: problems with ctrl-space [message #255948 is a reply to message #255913] Fri, 09 May 2008 07:32 Go to previous messageGo to next message
I'm using the Java editor.
For example:
I write pub (to complete to public) and press ctrl-space having no
response, anything happens.
If I begin to write a class name and I press ctrl-space I have the same
result.
On the other hand, if I write the complete name of a class or an instance
followed by a dot, then eclipse shows the different methods and
properties, but I can't complete them by using ctrl-space.
thanks
Re: problems with ctrl-space [message #255982 is a reply to message #255948] Fri, 09 May 2008 11:01 Go to previous messageGo to next message
ro wrote:
> For example:
> same result.
> instance followed by a dot, then eclipse shows the different methods
> and properties, but I can't complete them by using ctrl-space.
Try to reset the Java > Editor > Content Assist > Advanced prefs.
Dani
> thanks
Re: problems with ctrl-space [message #256096 is a reply to message #255982] Mon, 12 May 2008 03:56 Go to previous message
I have tried, but the problem persist.
I think that the problem is about the laptop, but I don't know what kind
of problems cause this.
thanks
Previous Topic:Importing libraries
Next Topic:How to Apply patch in Eclipse
Current Time: Fri Nov 07 15:31:30 EST 2025
Powered by FUDForum. Page generated in 0.10336 seconds
