Verify error for class name conflict [message #1436744] |
Fri, 03 October 2014 10:48 |
Chinthaka Dassanayake Messages: 1 Registered: October 2014 |
Junior Member |
I am trying to convert from KawaPro IDE (which is no longer supported) to Eclipse. I have a large set of library classes, some of which have the same name as classes in java run time libraries e.g. print.Doc. My projects compile and run in KawaPro. In Eclipse they compile well, but when I try to run, it throws up an verify error for example for my print.Doc even though I do not refer to javax.print.Doc from anywhere in my project. If I recompile from the command line or from KawaPro, it runs ok even from within Eclipse, until I compile again with Eclipse. Is there any way to solve this problem without renaming all the classes in my projects. I am using Eclipse Luna, and JRE 1.6. I tried several versions of Eclipse and JRE, but the problem persists. I have made sure that the problem arises when there is a class with same name as one in java run time library.
FUDForum. Page generated in 0.08023 seconds
