Home » Eclipse Projects » Buckminster dev » SVN access for new commiters
Re: SVN access for new commiters [message #25291 is a reply to message #25253] |
Fri, 05 September 2008 21:21 |
Hi Guillaume,
Try using password based authentication instead. That way you don't need the the generated
ssh keys, putty, etc.
Someone ought to revise the instructions on the wiki so that the password approach is the
recommended one. I just haven't had time to do it yet. Sorry.
Thomas Hallgren
Guillaume CHATELET wrote:
> I thought everything was ok because I succeeded in connecting to
> svn+ssh://dev.eclipse.org/svnroot/tools/org.eclipse.buckmins ter . I can
> connect, fetch, compare but commiting leads to
>> commit -m "Adding .qualifier to plugins"
>> T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.executor.test/META-INF/MANIFEST.MF
>> T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.executor/META-INF/MANIFEST.MF
>> T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.fetcher/META-INF/MANIFEST.MF
>> svn: Commit failed (details follow):
>> svn: Authorization failed
> Can anyone help me ?
> Best regards,
> Guillaume
>> Hi everyone,
>> At last ...I manage to get my ssh+svn running ...
>> The guide ( http://wiki.eclipse.org/Committer_access_(Buckminster) )
>> is very complicated and not very up to date. For instance, for the
>> client side, I managed to get it all running by adding my private key
>> to Eclipse and using the SVNKit Subclipse implementation (Pure Java) -
>> no tortoise or putty peageant needed.
>> Isn't it worth rewriting the document in order for the new committers
>> to be "up & running" quicker ?
>> I can do for the windows part but as I'm not sure it's also effective
>> for the other platforms I don't want to break everything.
>> What would you recommend ?
>> Regards,
>> Guillaume
Re: SVN access for new commiters [message #25332 is a reply to message #25291] |
Wed, 10 September 2008 10:07 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
I described that for the "Mac part", but did not take the time to check
what was needed on Windows at the same time.
And yes, the wiki page needs to be cleaned up - it is a mess.
- henrik
Thomas Hallgren wrote:
> Hi Guillaume,
> the the generated ssh keys, putty, etc.
> password approach is the recommended one. I just haven't had time to do
> it yet. Sorry.
> Regards,
> Thomas Hallgren
>> can connect, fetch, compare but commiting leads to
>> Best regards,
>> Guillaume
>>> Hi everyone,
>>> - no tortoise or putty peageant needed.
>>> Regards,
>>> Guillaume
Re: SVN access for new commiters [message #25414 is a reply to message #25332] |
Wed, 10 September 2008 12:25 |
I updated the page (to the best of my knowledge), please let me know if
the instructions does not work and I will change them.
> - henrik
>> Hi Guillaume,
>> need the the generated ssh keys, putty, etc.
>> do it yet. Sorry.
>> Regards,
>> Thomas Hallgren
>>> Best regards,
>>> Guillaume
>>>> Hi everyone,
>>>> key to Eclipse and using the SVNKit Subclipse implementation (Pure
>>>> Java) - no tortoise or putty peageant needed.
>>>> committers to be "up & running" quicker ?
>>>> effective for the other platforms I don't want to break everything.
>>>> Regards,
>>>> Guillaume
Current Time: Wed Sep 25 22:55:47 GMT 2024
Powered by FUDForum. Page generated in 0.05591 seconds
