Home » Archived » BIRT » The AXIS engine could not find a target service to invoke! targetService is null
The AXIS engine could not find a target service to invoke! targetService is null [message #255425] Fri, 14 September 2007 03:56 Go to next message
Originally posted by: teemu.turkia.propentus.fi
Hi!
I deployed BIRT 2.2.0 to WebSphere 6.0. index.jsp shows fine, but when I try
to run the test report, I get this error message:
null.
When I click "Show Exception Stack Trace", it shows only empty Stack Trace.
EAR classloader mode is set to parent last and WAR class loader policy is
set to Application. Also the web modules class loader mode is set to parent
last.
I have tried the default library structure and I also tried to remove emf
jars from platform/plugins directory (+ moved org.eclipse.emf_2.2.0...jar to
WEB-INF/lib folder) as described in
http://wiki.eclipse.org/Birt_WebSphere_Deployment. Nothing seems to help.
Any ideas what I am doing wrong?
Teemu Turkia
Re: The AXIS engine could not find a target service to invoke! targetService is null [message #255429 is a reply to message #255425] Fri, 14 September 2007 04:03 Go to previous messageGo to next message
Originally posted by: mil.methodpark.de
I have the same problem with tomcat 6...
Greetings,
Matthias
"Teemu Turkia" <teemu.turkia@propentus.fi> schrieb im Newsbeitrag
news:fcdev3$dnd$1@build.eclipse.org...
> Hi!
> try to run the test report, I get this error message:
> is null.
> Trace.
> parent last.
> to WEB-INF/lib folder) as described in
> Teemu Turkia
Re: The AXIS engine could not find a target service to invoke! targetService is null [message #255433 is a reply to message #255429] Fri, 14 September 2007 04:24 Go to previous messageGo to next message
Argh, I made a stupid mistake: I forgot to copy some config files
(server-config.wsdd, ...) to the appropriate folder of my webapp.
It works fine now!
Greetings,
Matthias
"Meandron" <mil@methodpark.de> schrieb im Newsbeitrag
news:fcdf8t$er4$1@build.eclipse.org...
> Greetings,
> Matthias
>> Hi!
>> is null.
>> Trace.
>> parent last.
>> Thanks,
>> Teemu Turkia
Re: The AXIS engine could not find a target service to invoke! targetService is null [message #255437 is a reply to message #255433] Fri, 14 September 2007 05:27 Go to previous message
Haha, I had the same problem. Shame on me! And thank you!
Teemu
"Meandron" <mil@methodpark.de> kirjoitti
viestiss
Previous Topic:Possible Bug in 2.2 when processing extended content in LocalizedContentVisitor
Next Topic:visualizing a database value
Current Time: Thu Nov 06 09:40:54 EST 2025
Powered by FUDForum. Page generated in 0.03268 seconds
