Re: Sequence Diagrams troubles [message #1434036 is a reply to message #1433981] |
Mon, 29 September 2014 15:15 |
Le 29/09/2014 16:31, O Bertrand a écrit :
> I try to make some sequence diagrams with the joined model.
> This model have objects and messages.
> i reproduced some example in UML model without any success. When i open my representation, i have an error message : Faild to create the part's control and an exception in error log : IllegalArgumentException ...
> I join my meta-model with the viewpoint project and a model.
> Where is my my mistake ?
It seems you should review your Sequence specific properties:
. Sequence Diagram Description
. endsOrdering: "[self/]" : the global ordering of all your event
ends is expected: a sorted list containing the start/finish of each
element displayed on the diagram. This is required for the layout
computation.
. Sequence delimited mappings:
. startingEndFinderExpression="var:self": here we expect an element
representing the start of your event. The element must also be in the
endsOrdering list computed of the diagram description.
. finishingEndFinderExpression="var:self": here we expect an
element representing the finish of your event. The element must also be
in the endsOrdering list computed of the diagram description.
See [1] for the Sequence Diagrams documentation.
> Regards,
> O. Bertrand
Maxime - Obeo
Need professional services for Sirius?
[1]
https://www.eclipse.org/sirius/doc/specifier/sequences/Sequence%20Diagrams.html
Maxime Porhel - Obeo
FUDForum. Page generated in 0.04081 seconds
