Re: Language Pack download page does not work [message #26154 is a reply to message #26072] |
Tue, 24 March 2009 13:10 |
Originally posted by: atoulme.intalio.com
Werner Keil wrote:
> The Ganymede update site works well.
> Just installed it on a German OS machine to test what I'm primarily
> dealing with (as German Language Champion)
> 2 things I noticed.
> 1. It seems there's some caching of UI resources until you use a
> particular editor...
> Since the "Hierarchy" tab was still in English after update and
> restarting Eclipse automatically.
> Once clicked on the tab it got "translated".
> A minor issue, but maybe at least in Galileo it could be fixed? (happy
> to file a Bugzilla entry, do you have an idea, whether this is on the
> Babel side, or rather core components of Eclipse?)
I think that would happen if there was some caching happening on the
framework for the plugin.properties files. I would be surprised that
this happens though... unless the plugin.properties file is read on the
plugin without starting the bundle, and the fragments are not looked up
at that point ( and I believe the UI does just that for the view names
for example, they read them and they only load the bundle when the view
is brought to front for the first time)... so yes, that looks like a
very big bug for the platform folks. I think it would go under Platform
> UI. Please paste the link of the bug here ?
> 2. Mylyn sticks out very badly in Ganymede. I know Mik and his folks
> promised to fix this with 3.2 Which is the target release for Galileo.
> So while his contribution in the Board was certainly much appreciated,
> stepping down and focussing on Mylyn and TaskTop (should a German,
> French or other translation of his product be desired?) may help Galileo
> to speak with a consistent tongue at least in the most common languages.
I don't graps the action item out of this. Can you be more explicit ? I
don't know of the history of this.
> Werner
Re: Language Pack download page does not work [message #577672 is a reply to message #26072] |
> 2 things I noticed.
> Werner
FUDForum. Page generated in 0.03574 seconds
