Home » Archived » BIRT » Detect No Data condition in Scripted data source
Detect No Data condition in Scripted data source [message #254630] Thu, 06 September 2007 10:07 Go to next message
Originally posted by: vencat.b.gmail.com
I want to detect "No Data" condition in scripted data source and display
appropriate message "No Data exists for your parameter selection" instead of
chart or table in report. How do i do this?
I tried to use count in open/fetch method and check if its 0, but after this
is executed there did not seem any way to prevent chart/table being
rendered. If i supress the chart / table then open/fetch method is not
executed.
Re: Detect No Data condition in Scripted data source [message #254860 is a reply to message #254630] Mon, 10 September 2007 11:25 Go to previous messageGo to next message
Venc,
There are a lot of ways to do this. You can add an aggregation to the
table that uses the scripted ds that counts the rows and use the
visibility feature. Take a look at this example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<scalar-parameter name="myrows" id="8">
<property name="valueType">static</property>
<property name="dataType">decimal</property>
<property name="controlType">text-box</property>
<property name="defaultValue">5</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<script-data-source name="Data Source" id="6"/>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="7">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">mydata</property>
<property name="dataType">integer</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">mydata</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[i = 0;]]></method>
<method name="fetch"><![CDATA[if( i >= params["myrows"] ){
return false;
}else{
row.mydata = i;
i++
return true;
}]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">if(row["RowCount"] == 0){
true;
}else{
false;
}</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["mydata"]</expression>
</structure>
<structure>
<property name="name">RowCount</property>
<expression name="expression">row.__rownum</expression>
<property name="aggregateFunction">count</property>
</structure>
<structure>
<property name="name">Column Binding</property>
<expression
name="expression">row["RowCount"]</expression>
</structure>
</list-property>
<column id="32"/>
<column id="18"/>
<header>
<row id="10">
<cell id="29"/>
<cell id="11">
<label id="12">
<text-property
name="text">mydata</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="30">
<data id="33">
<property name="resultSetColumn">Column
Binding</property>
</data>
</cell>
<cell id="14">
<data id="15">
<property
name="resultSetColumn">mydata</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="16">
<cell id="31"/>
<cell id="17"/>
</row>
</footer>
</table>
<table id="34">
<structure>
<expression name="valueExpr">if(row["RowCount"] == 0 ){
false;
}else{
true;
}</expression>
</structure>
</list-property>
<structure>
<expression
</structure>
<structure>
</structure>
</list-property>
<column id="43"/>
<header>
<row id="35">
<cell id="36">
<label id="37">
<text-property name="text">This Data Set
Contains No Data</text-property>
</label>
</cell>
</row>
</header>
<footer>
<row id="41">
<cell id="42"/>
</row>
</footer>
</table>
</body>
</report>
venc wrote:
> executed.
> Thanks
Re: Detect No Data condition in Scripted data source [message #254907 is a reply to message #254860] Mon, 10 September 2007 16:52 Go to previous messageGo to next message
Jason,
Does this work in 2.1.2 or 2.1.3? I tested your file but i get No Data
message all the time. Did not seem to work in 2.1.3. Is is possible the
aggregation is introduced in 2.2.x?
Thank you very much for responding to newsgroup queries.
-venkat
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:fc3ngc$t0k$1@build.eclipse.org...
> Venc,
> Jason
> id="1">
> <property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name
> here>></property>
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> return false;
> }else{
> row.mydata = i;
> i++
> return true;
> }]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> true;
> }else{
> false;
> }</expression>
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="32"/>
> <column id="18"/>
> <header>
> <row id="10">
> <cell id="29"/>
> <cell id="11">
> <label id="12">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="13">
> <cell id="30">
> <data id="33">
> Binding</property>
> </data>
> </cell>
> <cell id="14">
> <data id="15">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="16">
> <cell id="31"/>
> <cell id="17"/>
> </row>
> </footer>
> </table>
> <table id="34">
> <structure>
> 0 ){
> false;
> }else{
> true;
> }</expression>
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="43"/>
> <header>
> <row id="35">
> <cell id="36">
> <label id="37">
> </label>
> </cell>
> </row>
> </header>
> <footer>
> <row id="41">
> <cell id="42"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
> venc wrote:
>> display appropriate message "No Data exists for your parameter selection"
>> instead of chart or table in report. How do i do this?
>> this is executed there did not seem any way to prevent chart/table being
>> executed.
>> Thanks
Re: Detect No Data condition in Scripted data source [message #254929 is a reply to message #254907] Mon, 10 September 2007 18:46 Go to previous messageGo to next message
Venc,
I apologize. I did this in 2.2. You should be able to build an
aggregate using the Total functions in earlier versions.
Jason
venc wrote:
> Jason,
> -venkat
>> Venc,
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> here>></property>
>> <parameters>
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> <data-sources>
>> </data-sources>
>> <data-sets>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> return false;
>> }else{
>> row.mydata = i;
>> i++
>> return true;
>> }]]></method>
>> </script-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="9">
>> <structure>
>> true;
>> }else{
>> false;
>> }</expression>
>> </structure>
>> </list-property>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="32"/>
>> <column id="18"/>
>> <header>
>> <row id="10">
>> <cell id="29"/>
>> <cell id="11">
>> <label id="12">
>> <text-property
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="13">
>> <cell id="30">
>> <data id="33">
>> Binding</property>
>> </data>
>> </cell>
>> <cell id="14">
>> <data id="15">
>> <property
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="16">
>> <cell id="31"/>
>> <cell id="17"/>
>> </row>
>> </footer>
>> </table>
>> <table id="34">
>> <structure>
>> 0 ){
>> false;
>> }else{
>> true;
>> }</expression>
>> </structure>
>> </list-property>
>> <structure>
>> <expression
>> </structure>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <column id="43"/>
>> <header>
>> <row id="35">
>> <cell id="36">
>> <label id="37">
>> </label>
>> </cell>
>> </row>
>> </header>
>> <footer>
>> <row id="41">
>> <cell id="42"/>
>> </row>
>> </footer>
>> </table>
>> </body>
>> </report>
>> venc wrote:
>>> Hi,
>>> executed.
>>> Thanks
Re: Detect No Data condition in Scripted data source [message #254956 is a reply to message #254929] Mon, 10 September 2007 20:22 Go to previous messageGo to next message
Thanks jason. This is my solution:
a) Create a hidden parameter NoData which is boolean and set to false by
default
b) In fetch method
if(i==0) params["NoData"]=true;
return false;
}else{
row.mydata = i;
i++
return true;
And then created suppression formula: if(params["NoData")==true) { false; }
else { true; }
I might be wrong but the problem with your approach is binding same dataset
to two different tables might cause scripted datasource to be executed
twice. I havent tested this but thats my hunch. But your approach definitely
helped me in right direction.
Many thanks as always for frequently responding to our questions in this
forum.
news:fc4hb8$1dt$2@build.eclipse.org...
> Venc,
> I apologize. I did this in 2.2. You should be able to build an aggregate
> Jason
> venc wrote:
>> Jason,
>> -venkat
>>> Venc,
>>> Jason
>>> id="1">
>>> <parameters>
>>> </structure>
>>> </scalar-parameter>
>>> </parameters>
>>> <data-sources>
>>> </data-sources>
>>> <data-sets>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> return false;
>>> }else{
>>> row.mydata = i;
>>> i++
>>> return true;
>>> }]]></method>
>>> </script-data-set>
>>> </data-sets>
>>> <styles>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <table id="9">
>>> <structure>
>>> 0){
>>> true;
>>> }else{
>>> false;
>>> }</expression>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> <expression
>>> </structure>
>>> <structure>
>>> <expression
>>> </structure>
>>> <structure>
>>> <expression
>>> </structure>
>>> </list-property>
>>> <column id="32"/>
>>> <column id="18"/>
>>> <header>
>>> <row id="10">
>>> <cell id="29"/>
>>> <cell id="11">
>>> <label id="12">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="13">
>>> <cell id="30">
>>> <data id="33">
>>> Binding</property>
>>> </data>
>>> </cell>
>>> <cell id="14">
>>> <data id="15">
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="16">
>>> <cell id="31"/>
>>> <cell id="17"/>
>>> </row>
>>> </footer>
>>> </table>
>>> <table id="34">
>>> <structure>
>>> 0 ){
>>> false;
>>> }else{
>>> true;
>>> }</expression>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> <expression
>>> </structure>
>>> <structure>
>>> <expression
>>> </structure>
>>> </list-property>
>>> <column id="43"/>
>>> <header>
>>> <row id="35">
>>> <cell id="36">
>>> <label id="37">
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <footer>
>>> <row id="41">
>>> <cell id="42"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </body>
>>> </report>
>>> venc wrote:
>>>> Hi,
>>>> selection" instead of chart or table in report. How do i do this?
>>>> being rendered. If i supress the chart / table then open/fetch method
>>>> is not executed.
>>>> Thanks
Re: Detect No Data condition in Scripted data source [message #255069 is a reply to message #254956] Tue, 11 September 2007 11:39 Go to previous message
Venc,
You are correct about the data sets being executed twice. This should
get fixed in 2.2.1. I like your approach much better. Thanks for
posting it.
Jason
> default
> b) In fetch method
> return false;
> }else{
> row.mydata = i;
> i++
> return true;
> else { true; }
> forum.
>> Venc,
>> Jason
>> venc wrote:
>>> Jason,
>>> -venkat
>>>> Venc,
>>>> Jason
>>>> id="1">
>>>> <parameters>
>>>> </structure>
>>>> </scalar-parameter>
>>>> </parameters>
>>>> <data-sources>
>>>> </data-sources>
>>>> <data-sets>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </structure>
>>>> return false;
>>>> }else{
>>>> row.mydata = i;
>>>> i++
>>>> return true;
>>>> }]]></method>
>>>> </script-data-set>
>>>> </data-sets>
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <table id="9">
>>>> <structure>
>>>> 0){
>>>> true;
>>>> }else{
>>>> false;
>>>> }</expression>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> </list-property>
>>>> <column id="32"/>
>>>> <column id="18"/>
>>>> <header>
>>>> <row id="10">
>>>> <cell id="29"/>
>>>> <cell id="11">
>>>> <label id="12">
>>>> <text-property
>>>> </label>
>>>> </cell>
>>>> </row>
>>>> </header>
>>>> <detail>
>>>> <row id="13">
>>>> <cell id="30">
>>>> <data id="33">
>>>> Binding</property>
>>>> </data>
>>>> </cell>
>>>> <cell id="14">
>>>> <data id="15">
>>>> <property
>>>> </data>
>>>> </cell>
>>>> </row>
>>>> </detail>
>>>> <footer>
>>>> <row id="16">
>>>> <cell id="31"/>
>>>> <cell id="17"/>
>>>> </row>
>>>> </footer>
>>>> </table>
>>>> <table id="34">
>>>> <structure>
>>>> 0 ){
>>>> false;
>>>> }else{
>>>> true;
>>>> }</expression>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> <structure>
>>>> <expression
>>>> </structure>
>>>> </list-property>
>>>> <column id="43"/>
>>>> <header>
>>>> <row id="35">
>>>> <cell id="36">
>>>> <label id="37">
>>>> </label>
>>>> </cell>
>>>> </row>
>>>> </header>
>>>> <footer>
>>>> <row id="41">
>>>> <cell id="42"/>
>>>> </row>
>>>> </footer>
>>>> </table>
>>>> </body>
>>>> </report>
>>>> venc wrote:
>>>>> Hi,
>>>>> is not executed.
>>>>> Thanks
Previous Topic:Deploying custom ODA driver to BIRT runtime
Next Topic:Report Engine fails to initialize html emitter
Current Time: Mon Oct 27 19:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.33717 seconds
