| org.eclipse.acceleo.engine.AcceleoEvaluationException [message #1431349] |
Thu, 25 September 2014 11:12   |
Eclipse User  |
Here is the exception:  Exception in thread "main" org.eclipse.acceleo.engine.AcceleoEvaluationException: The type of the first parameter of the main template named 'generateElement' is a proxy.
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:632)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:211)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:172)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:159)
	at com.att.itos.workflow.acceleco.test1.common.Generate.doGenerate(Generate.java:206)
	at com.att.itos.workflow.acceleco.test1.common.Generate.main(Generate.java:164)
This is where it is thrown:
Class:
Method : doGenerate
Here is where the exception is thrown:
	if (argumentType.eIsProxy()) {
				throw new AcceleoEvaluationException(AcceleoEngineMessages.getString(
						"AcceleoService.TypeIsProxy", templateName)); //$NON-NLS-1$
argumentType is :
org.eclipse.emf.ecore.impl.EClassImpl@2d5534 (eProxyURI: file:/C:/Users/rl8840/WorkspaceATT2/com.att.itos.workflow.acceleco.test1/bin/com/att/itos/workflow/acceleco/test1/common/www.att.com/WorkflowScreenModel#//UserStory)
I dont understand why it is a eProxyURI, which is causing the exception to be thrown.
FUDForum. Page generated in 0.05209 seconds
