Re: Creating Sirius Diagram - in headless plugin [message #1429575 is a reply to message #1429539] |
Tue, 23 September 2014 12:19 |
Esteban Dugueperoux Messages: 472 Registered: July 2009 |
Can you provide the plugin which execute this snippet?
It seems that your plugin have not enough sirius dependencies, for
example org.eclipse.sirius.diagram.ui plugin.
Best Regards.
Le 23/09/2014 13:18, VVasanth Kumar a écrit :
> By Headless - I mean 'Eclipse Headless Plugin' (please refer [1]).
> My requirement is - I will be generating my model through java (outside
> of Eclipse). Once generated, I will access the model in Eclipse. Now, I
> am trying to generate Sirius diagram directly (instead of generating
> model first and then creating diagram through Eclipse).
> Please find the snippet of my code below:
> prj.get().getMainRepresentationsFileURI(new
> NullProgressMonitor(), false, false);
> IProject project =
> ResourcesPlugin.getWorkspace().getRoot().getProject("TestSiriusHeadless");
> //My project name
> Session existingSession = null;
> try {
> project.open(new NullProgressMonitor());
> } catch (CoreException e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> final Option<ModelingProject> prj =
> ModelingProject
> .asModelingProject(project);
> if (prj.some()) {
> existingSession = prj.get().getSession();
> if (existingSession == null) {
> Option<org.eclipse.emf.common.util.URI> optionalMainSessionFileURI =
> prj.get()
> new
> if
> (optionalMainSessionFileURI.some()) {
> // Load the main
> representations file of this modeling
> // project if it's not
> already loaded or during loading.
> ModelingProjectManager.INSTANCE
> .loadAndOpenRepresentationsFile(optionalMainSessionFileURI
> .get());
> In the above snippet, I am getting following sequence of error while
> executing the statement 'final Option<ModelingProject> prj =
> ModelingProject.asModelingProject(project);'.
> Could you please help me in solving this issue?
> org.eclipse.core.runtime.CoreException: Plug-in
> org.eclipse.sirius.diagram.ui was unable to load class
> org.eclipse.sirius.diagram.ui.business.internal.migration.description.OptionalLayersVSMMigrationParticipant.
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
> at
> org.eclipse.sirius.business.internal.migration.AbstractSiriusMigrationService.loadContributions(AbstractSiriusMigrationService.java:72)
> at
> org.eclipse.sirius.business.internal.migration.description.VSMMigrationService.<init>(VSMMigrationService.java:27)
> at
> org.eclipse.sirius.business.internal.migration.description.VSMMigrationService.<clinit>(VSMMigrationService.java:24)
> at
> org.eclipse.sirius.viewpoint.description.util.DescriptionResourceFactoryImpl.createResource(DescriptionResourceFactoryImpl.java:63)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:434)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.load(ViewpointRegistryImpl.java:603)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.registerFromPlugin(ViewpointRegistryImpl.java:282)
> at defaultpackage.Activator.start(Activator.java:38)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
> at
> at
> at
> at
> org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:137)
> at
> org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:79)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.initViewpointsFromPlugins(ViewpointRegistryImpl.java:615)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.init(ViewpointRegistryImpl.java:153)
> at
> org.eclipse.sirius.viewpoint.SiriusPlugin.initPreferences(SiriusPlugin.java:173)
> at
> org.eclipse.sirius.viewpoint.SiriusPlugin.start(SiriusPlugin.java:154)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
> at
> at
> at
> at com.cts.Sirius.SiriusTest.createDiagram(SiriusTest.java:233)
> at myheadlessplugin.Application.start(Application.java:18)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
> Caused by:
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException:
> An error occurred while automatically activating bundle
> org.eclipse.sirius.diagram.ui (748).
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:124)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> Caused by: org.osgi.framework.BundleException: The activator
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin$Implementation
> for bundle org.eclipse.sirius.diagram.ui is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
> at
> at
> at
> at
> at
> ... 88 more
> Caused by: java.lang.NoClassDefFoundError:
> org/eclipse/sirius/viewpoint/provider/SiriusEditPlugin
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin.<init>(DiagramUIPlugin.java:105)
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin.<clinit>(DiagramUIPlugin.java:89)
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin$Implementation.<init>(DiagramUIPlugin.java:163)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
> Method)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown
> Source)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
> at java.lang.reflect.Constructor.newInstance(Unknown Source)
> at java.lang.Class.newInstance(Unknown Source)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
> ... 94 more
> Caused by:
> org.eclipse.sirius.ui (774).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> Caused by: org.osgi.framework.BundleException: Exception in
> org.eclipse.sirius.viewpoint.provider.SiriusEditPlugin$Implementation.start()
> of bundle org.eclipse.sirius.ui.
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
> at
> at
> at
> at
> at
> at
> ... 112 more
> Caused by: java.lang.IllegalStateException: Workbench has not been
> created yet.
> at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
> at
> org.eclipse.sirius.viewpoint.provider.SiriusEditPlugin$Implementation.start(SiriusEditPlugin.java:214)
> at
> at
> ... 118 more
> !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-23 08:17:08.707
> !MESSAGE Plug-in org.eclipse.sirius.diagram.ui was unable to load class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 88 more
> at
> at
> at
> Method)
> Source)
> at
> at
> ... 94 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> at
> at
> at
> at
> at
> at
> at
> ... 112 more
> created yet.
> at
> at
> at
> ... 118 more
> !ENTRY org.eclipse.sirius 2 0 2014-09-23 08:17:08.823
> !MESSAGE Cannot instanciate migration contribution
> !STACK 1
> org.eclipse.sirius.diagram.ui.business.internal.migration.DiagramSplitMigrationParticipant.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> at
> at
> at
> at
> at
> at
> at
> ... 88 more
> at
> at
> at
> Method)
> Source)
> at
> at
> ... 94 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> at
> at
> at
> at
> at
> at
> at
> ... 112 more
> created yet.
> at
> at
> at
> ... 118 more
> !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-23 08:17:08.915
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.se
FUDForum. Page generated in 0.04662 seconds
