| Using documents with parameters [message #253788] |
Wed, 29 August 2007 00:00 |
I have generated rptdocument file from rptdesign with parameters. I set
values for all parameters and generation task has been completed
successfull. When I open this document in Web application using
/frameset?__document=path_to_my_file url, I see button "Run Report" on
the toolbar which shows input parameters dialog and let me run document
with other values of parameters.
1. BIRT document can use parameters? I guess that BIRT docuement cannot
use parameters, because it is contain all data for presentation step and
this data cannot be changed.
2. How it will be work if I have binding for query text property of data
set which references to global report parameter?
3. Can I hide this toolbar button?
Boris Stepanov
FUDForum. Page generated in 0.02692 seconds
