Home » Eclipse Projects » Riena » MasterDetailComposite
Re: MasterDetailComposite [message #25323 is a reply to message #24995] |
Tue, 05 May 2009 06:46 |
Originally posted by: eclipse-dev.volanakis.de
--------------080005050302080603070306
Hi Gabe,
> * Hide or remove "New", "Remove", and "Apply" buttons?
yes, that's easy:
IMasterDetailsRidget ridget;
ridget.getRidget(MasterDetailsComposite.BIND_ID_APPLY).setVi sible(false);
// see MasterDetailsComposite for other constants
> * Have master table updated as I type in the detail widgets (instead of
> when "Apply" is clicked)?
Theoretically yes - practically no. Two problems here:
(a) there is no official API;
(b) apply clears the details area
See the attached snippet for an example (not useful because of (b)).
Best open a bug with your requirements / use-case and we can continue
the discussion there.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Riena
Kind regards,
Elias.
name="Snippet.java"
Content-Disposition: inline;
filename="Snippet.java"
* Copyright (c) 2007, 2009 compeople AG and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* compeople AG - initial API and implementation
package org.eclipse.riena.sample.snippets;
import java.beans.PropertyChangeListener;
import org.eclipse.core.databinding.observable.list.WritableList;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.jface.layout.GridLayoutFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.riena.beans.common.Person;
import org.eclipse.riena.beans.common.PersonFactory;
import org.eclipse.riena.internal.ui.ridgets.swt.MasterDetailsRidge t;
import org.eclipse.riena.ui.core.marker.ValidationTime;
import org.eclipse.riena.ui.ridgets.IMasterDetailsDelegate;
import org.eclipse.riena.ui.ridgets.IMasterDetailsRidget;
import org.eclipse.riena.ui.ridgets.IRidget;
import org.eclipse.riena.ui.ridgets.IRidgetContainer;
import org.eclipse.riena.ui.ridgets.ITextRidget;
import org.eclipse.riena.ui.ridgets.swt.SwtRidgetFactory;
import org.eclipse.riena.ui.ridgets.validation.NotEmpty;
import org.eclipse.riena.ui.swt.MasterDetailsComposite;
import org.eclipse.riena.ui.swt.utils.UIControlsFactory;
* A master details ridget. The master area shows a table of persons. The detail
* area can rename a person.
public final class Snippet {
private Snippet() {
// "utility class"
* A master details widget with a text fields for renaming a person.
private static final class PersonMasterDetails extends MasterDetailsComposite {
PersonMasterDetails(Composite parent, int style) {
super(parent, style, SWT.BOTTOM);
protected void createDetails(Composite parent) {
GridLayoutFactory.fillDefaults().numColumns(2).margins(20, 20).spacing(10, 10).equalWidth(false).applyTo(
parent);
GridDataFactory hFill = GridDataFactory.fillDefaults().grab(true, false);
UIControlsFactory.createLabel(parent, "Last Name:"); //$NON-NLS-1$
Text txtLast = UIControlsFactory.createText(parent);
hFill.applyTo(txtLast);
addUIControl(txtLast, "txtLast"); //$NON-NLS-1$
UIControlsFactory.createLabel(parent, "First Name:"); //$NON-NLS-1$
Text txtFirst = UIControlsFactory.createText(parent);
hFill.applyTo(txtFirst);
addUIControl(txtFirst, "txtFirst"); //$NON-NLS-1$
protected int getDetailsStyle() {
return SWT.BORDER;
* A IMasterDetailsDelegate that renames a person.
private static final class PersonDelegate implements IMasterDetailsDelegate {
private final Person workingCopy = createWorkingCopy();
public void configureRidgets(final IRidgetContainer container) {
ITextRidget txtLast = (ITextRidget) container.getRidget("txtLast"); //$NON-NLS-1$
txtLast.bindToModel(workingCopy, Person.PROPERTY_LASTNAME);
txtLast.addValidationRule(new NotEmpty(), ValidationTime.ON_UI_CONTROL_EDIT);
txtLast.updateFromModel();
ITextRidget txtFirst = (ITextRidget) container.getRidget("txtFirst"); //$NON-NLS-1$
txtFirst.bindToModel(workingCopy, Person.PROPERTY_FIRSTNAME);
txtFirst.updateFromModel();
PropertyChangeListener listener = new PropertyChangeListener() {
public void propertyChange(java.beans.PropertyChangeEvent event) {
System.out.println("pcl: " + event.getNewValue());
if (isValid(container) == null) {
// non API - use at own peril
// note that apply does deselect; so this is not very useful
((MasterDetailsRidget) container).handleApply();
txtLast.addPropertyChangeListener(ITextRidget.PROPERTY_TEXT, listener);
txtFirst.addPropertyChangeListener(ITextRidget.PROPERTY_TEXT , listener);
public Person copyBean(Object source, Object target) {
Person from = source != null ? (Person) source : createWorkingCopy();
Person to = target != null ? (Person) target : createWorkingCopy();
to.setFirstname(from.getFirstname());
to.setLastname(from.getLastname());
return to;
public Person createWorkingCopy() {
return new Person("", ""); //$NON-NLS-1$ //$NON-NLS-2$
public Person getWorkingCopy() {
return workingCopy;
public boolean isChanged(Object source, Object target) {
Person p1 = (Person) source;
Person p2 = (Person) target;
boolean equal = p1.getFirstname().equals(p2.getFirstname()) && p1.getLastname().equals(p2.getLastname());
return !equal;
public String isValid(IRidgetContainer container) {
if (txtLast.isErrorMarked()) {
return "'Last Name' is not valid."; //$NON-NLS-1$
return null;
public void updateDetails(IRidgetContainer container) {
for (IRidget ridget : container.getRidgets()) {
ridget.updateFromModel();
Display display = Display.getDefault();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
PersonMasterDetails details = new PersonMasterDetails(shell, SWT.NONE);
IMasterDetailsRidget ridget = (IMasterDetailsRidget) SwtRidgetFactory.createRidget(details);
ridget.setDelegate(new PersonDelegate());
WritableList input = new WritableList(PersonFactory.createPersonList(), Person.class);
String[] properties = { Person.PROPERTY_LASTNAME, Person.PROPERTY_FIRSTNAME };
String[] headers = { "Last Name", "First Name" }; //$NON-NLS-1$ //$NON-NLS-2$
ridget.bindToModel(input, Person.class, properties, headers);
* Hide the REMOVE and APPLY buttons
ridget.getRidget(MasterDetailsComposite.BIND_ID_REMOVE).setV isible(false);
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
--------------080005050302080603070306--
Re: MasterDetailComposite [message #582188 is a reply to message #24995] |
Elias Volanakis Messages: 43 Registered: July 2009 |
Member |
Hi Gabe,
yes, that's easy:
Kind regards,
Elias.
name="Snippet.java"
* Contributors:
private Snippet() {
// "utility class"
parent);
return SWT.BORDER;
return to;
return workingCopy;
return !equal;
return null;
shell.pack();
shell.open();
display.sleep();
display.dispose();
Current Time: Sat Sep 21 00:01:01 GMT 2024
Powered by FUDForum. Page generated in 0.03255 seconds
