Home » Eclipse Projects » Eclipse Platform » Help: DialogCellEditor does not work properly
Help: DialogCellEditor does not work properly [message #253347] Wed, 16 June 2004 14:08 Go to next message
I have created a custom DialogCellEditor the displays the FontDialog.
When I click in a table cell, the DialogCellEditor appears, I hit return,
and the FontDialog appears just like I expect. I select a font, click
ok, the FontDialog disappears, but the DialogCellEditor is still visible
in the table cell. Clicking another cell will bring up the appropriate
editor for that cell, but the table display becomes corrupted with the
DialogCellEditor. Any ideas on what I might have done wrong, or is this
a bug?
Bryan
Here is my DialogCellEditor:
* Created on Jun 16, 2004
* Copyright (c) 2004 International Business Machines
package com.ibm.hdwb.data.ui.tableFormatEditor;
import org.eclipse.jface.viewers.DialogCellEditor;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.FontDialog;
* @author bhunt
public class FontCellEditor extends DialogCellEditor
* @param parent
public FontCellEditor(Composite parent)
super(parent);
* @see org.eclipse.jface.viewers.DialogCellEditor#openDialogBox(org .
eclipse.swt.widgets.Control)
protected Object openDialogBox(Control cellEditorWindow)
return new FontDialog(cellEditorWindow.getShell()).open();
Re: Help: DialogCellEditor does not work properly [message #268931 is a reply to message #253347] Thu, 26 August 2004 18:38 Go to previous messageGo to next message
In case you still need an answer, I had the same problem and solved it by overriding the method
createButton() like this:
protected Button createButton (final Composite parent, Font font) {
final Button button = super.createButton(parent, font);
button.addFocusListener(new FocusAdapter() {
public void focusLost (final FocusEvent e) {
if (!_dialogOpen) {
fireCancelEditor();
// generates "pop-down" when user "clicks out"
return button;
Then, in method openDialogBox(), be sure to set and unset the boolean _dialogOpen:
protected Object openDialogBox (final Control cellEditorWindow) {
final Dialog dialog = initialiseDialogHoweverYouNeedTo();
_dialogOpen = true;
final boolean ok = (dialog.open() == WizardDialog.OK);
final String result = getResultHoweverYouNeedTo();
_dialogOpen = false;
return result;
HTH,
Paul
> a bug?
> Bryan
> * @author bhunt
> * @param parent
> super(parent);
Re: Help: DialogCellEditor does not work properly [message #269080 is a reply to message #268931] Fri, 27 August 2004 17:30 Go to previous message
Do you think it is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=34819
Genady
Genady Beryozkin
http://www.genady.net/
> by overriding the method createButton() like this:
> if (!_dialogOpen) {
> fireCancelEditor();
> return button;
> _dialogOpen:
> _dialogOpen = true;
> return result;
> HTH,
> Paul
>> FontDialog. When I click in a table cell, the DialogCellEditor
>> appears, I hit return, and the FontDialog appears just like I
>> expect. I select a font, click ok, the FontDialog disappears, but
>> the DialogCellEditor is still visible in the table cell. Clicking
>> another cell will bring up the appropriate editor for that cell, but
>> the table display becomes corrupted with the DialogCellEditor. Any
>> ideas on what I might have done wrong, or is this a bug?
>> Bryan
>> * @author bhunt
>> * @param parent
>> super(parent);
>> * @see
Previous Topic:How to import a .launch file? (Darin S.?)
Next Topic:eclipse3, svn and synchronization
Current Time: Wed Nov 05 17:00:26 EST 2025
Powered by FUDForum. Page generated in 0.03430 seconds
