| LDT debugger error [message #1425548] |
Wed, 17 September 2014 09:11  |
1. I use the local interpreter named luajit
2. I have installed luasocket, and pass verification by terminal.
3. when I debug my lua script in LDT, the debugger below happens.
I need help. Thanks so much.
The debugger errro information is below:
Debugger v1.1.0
Debugger: Trying to connect to 127.0.0.1:10000 ...
Debugger: Connection succeed.
DEBUGGER ERROR Command context_get caused: (998) /usr/local/share/lua/5.1/ltn12.lua:41: bad argument #1 to 'getn' (table expected, got nil)
stack traceback:
[C]: in function 'getn'
/usr/local/share/lua/5.1/ltn12.lua:41: in function 'chain'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:187: in function 'b64'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:1427: in function 'make_property'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:649: in function
< .../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:638>
[C]: in function 'xpcall'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:3080: in function
<.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:3050>
[C]: in function 'pcall'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:3135: in function 'line_hook'
.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:3142: in function
<.../org.eclipse.osgi/173/0/.cp/script/external/debugger.lua:3140>
FUDForum. Page generated in 0.03440 seconds
