Home » Archived » BIRT » XML Datasource
XML Datasource [message #252540] Wed, 15 August 2007 10:44 Go to next message
Originally posted by: jens.neuhaus.gmx.de
we used to have a servlet, which gets query parameters and deliver an xml
stream. First i tried to use a XML datasource, but I found no way to pass
the parameters to the datasource at runtime, because i have to define a
fixed datasource url.
Is there a way to modify the xml destination, before it will be called?
That would allow me to add the parameters as a querystring.
If this is not possible, is it the right way to use a scripted datasource,
parse the xml document into pojos and map the pojo attributes to dataset
attributes? That's from my perspective not really clever, because you have
to code many lines for each report.
Do you have any other ideas? Sadly the chapter 'XML- Datasource' is really
short in the 'field guide' or the 'integration & extending'.
Thanks for any help in advance.
Greetings Jens
Re: XML Datasource [message #252659 is a reply to message #252540] Wed, 15 August 2007 20:18 Go to previous message
Jens,
You should be able to change the xml url in property binding of the data
source or through the beforeOpen script like:
this.setExtensionProperty("FILELIST", "file:///c:/temp/xmltest2.xml");
Jason
Jens Neuhaus wrote:
> Hello,
> xml stream. First i tried to use a XML datasource, but I found no way to
> pass the parameters to the datasource at runtime, because i have to
> define a fixed datasource url.
> datasource, parse the xml document into pojos and map the pojo
> attributes to dataset attributes? That's from my perspective not really
> clever, because you have to code many lines for each report.
> really short in the 'field guide' or the 'integration & extending'.
> Greetings Jens
Previous Topic:Best Practices for Secuirty and Authorization w/in Birt
Next Topic:row._outer problem
Current Time: Tue Jul 08 09:06:08 EDT 2025
Powered by FUDForum. Page generated in 0.28996 seconds
