Home » Modeling » TMF (Xtext) » Qualified name relative to a namespace import?
Re: Qualified name relative to a namespace import? [message #1424205 is a reply to message #1424189] |
Mon, 15 September 2014 16:39 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Stephan,
no, this doesn't work out of the box. You'd have to adjust
ImportedNamespaceAwareLocalScopeProvider.doCreateImportNormalizer(QualifiedName,
boolean, boolean) to use that feature together with the
importedNamespace convenience.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 15.09.14 18:06, schrieb Stephan Herrmann:
> I'm in the process of migrating a pile of DSLs from importURI to
> importedNamespace.
> At the point where I believe my qualified name providers and scope
> providers are in a fairly good shape, I'm trying to achieve that an
> element with name x.y.z can be referenced by
> - importing x.y and - using y.z as the reference (just as you would do
> for static members in Java).
> Since y is in scope, I want to interpret y.z as a qualified name
> relative to that y.
> Is this supposed to work out of the box (i.e., I broke it by some
> customization)?
> Is possible by some additional tweak?
> Does this need to be implemented manually?
> I've seen solutions with an explicit sub-grammar for dot expressions,
> but this isn't so attractive, for two reasons: (a) it seems to require
> to define this for every reference in the grammar that should make use
> of this concept, and (b) it seems to require knowledge about the
> intermediate types, but if z can be reached via x.y.z and x.a.z those
> 'y' and 'a' could possibly be of unrelated types.
> cheers,
> Stephan
> PS: this is at Xtext 2.4.3. Migration to 2.7.1 has been deferred until
> after the import change is complete ... not sure if this matters for the
> issue at hand.
Re: Qualified name relative to a namespace import? [message #1424263 is a reply to message #1424217] |
Mon, 15 September 2014 18:36 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
FWIW: this is what I came up with:
public class MyImportedNamespaceAwareLocalScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
protected ImportNormalizer doCreateImportNormalizer(QualifiedName importedNamespace, boolean wildcard, boolean ignoreCase) {
return new JoiningImportNormalizer(importedNamespace, wildcard, ignoreCase);
static class JoiningImportNormalizer extends ImportNormalizer {
public JoiningImportNormalizer(QualifiedName importedNamespace, boolean wildCard, boolean ignoreCase) {
super(importedNamespace, wildCard, ignoreCase);
public QualifiedName resolve(QualifiedName relativeName) {
if (relativeName.getSegmentCount() > 1 && !hasWildCard()) {
String pivot = relativeName.getFirstSegment();
if (isIgnoreCase())
pivot = pivot.toLowerCase();
QualifiedName importPrefix = getImportedNamespacePrefix();
if (pivot.equals(importPrefix.getLastSegment()))
return importPrefix.append(relativeName.skipFirst(1));
return super.resolve(relativeName);
public QualifiedName deresolve(QualifiedName fullyQualifiedName) {
if (!hasWildCard()) {
if (fullyQualifiedName.startsWith(importPrefix))
return fullyQualifiedName.skipFirst(importPrefix.getSegmentCount()-1);
return super.deresolve(fullyQualifiedName);
No rocket science in fact, but looks indeed re-usable. Would Xtext like to adopt s.t. like this?
I wonder what use cases this might break, but since normal ImportNormalizers only do their work for segment count == 1 we seem to handle disjoint use cases.
Or did you have specific reasons, *not* to implement such behavior?
best,
Stephan
Re: Qualified name relative to a namespace import? [message #1424626 is a reply to message #1424263] |
Tue, 16 September 2014 07:35 |
Hi Stephan,
from the top of my head I don't remember if explicitly opted out from
that behavior. So a ticket + a patch would be nice.
Sebastian
Am 15.09.14 20:36, schrieb Stephan Herrmann:
> @Override
> ignoreCase);
> @Override
> if (isIgnoreCase())
> @Override
> return
> best,
> Stephan
Current Time: Sat Apr 27 02:16:15 GMT 2024
Powered by FUDForum. Page generated in 0.03370 seconds
