| running eclipse on VMwared RHEL 4.6 does not work [message #252277] |
Mon, 24 March 2008 14:16 |
Hello group,
I asked this question, but did not get any solvable reply. Please let me
know if this is a prevalent issue in the community and how can I solve it.
I have a RHEL 5 box. On RHEL 5 box I installed (VMwared) RHEL 4.6.
I have an eclipse verions installed on RHEL 5, which works. But the same
version on RHEL 4 does not work. It comes up with following messages. It
seems I have to set up some "windows screen parameters" like GtkWindow.
I have installed a new copy of eclipse for RHEL 4 instead of using RHEL 5
copy, and it still does not work.
Here are the messages. Can someone please help.
(:7803): Gtk-WARNING **: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
(:7803): Gdk-CRITICAL **: file gdkscreen-x11.c: line 122
(gdk_screen_get_display): assertion `GDK_IS_SCREEN (screen)' failed
(:7803): Gdk-CRITICAL **: file gdkdisplay.c: line 478
(gdk_display_get_pointer): assertion `GDK_IS_DISPLAY (display)' failed
(:7803): Gdk-CRITICAL **: file gdkscreen-x11.c: line 339
(gdk_screen_get_n_monitors): assertion `GDK_IS_SCREEN (screen)' failed
(:7803): Gdk-CRITICAL **: file gdkscreen-x11.c: line 363
(gdk_screen_get_monitor_geometry): assertion `GDK_IS_SCREEN (screen)'
failed
(:7803): Gdk-CRITICAL **: file gdkscreen-x11.c: line 250
(gdk_screen_get_default_colormap): assertion `GDK_IS_SCREEN (screen)'
failed
(:7803): Gdk-CRITICAL **: file gdkcolor.c: line 72
(gdk_colormap_get_visual): assertion `GDK_IS_COLORMAP (colormap)' failed
failed
(:7803): Gdk-CRITICAL **: file gdkscreen-x11.c: line 232
(gdk_screen_get_root_window): assertion `GDK_IS_SCREEN (screen)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 575 (gdk_window_new):
assertion `GDK_IS_WINDOW (parent)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 5451
(gdk_window_enable_synchronized_configure_libgtk_only): assertion
`GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow.c: line 471
(gdk_window_set_user_data): assertion `window != NULL' failed
(:7803): Gtk-CRITICAL **: file gtkstyle.c: line 841 (gtk_style_attach):
(:7803): Gtk-CRITICAL **: file gtkstyle.c: line 1652
(gtk_style_set_background): assertion `GTK_IS_STYLE (style)' failed
(:7803): Gtk-CRITICAL **: file gtkstyle.c: line 6090 (gtk_paint_flat_box):
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 4290
(gdk_window_set_decorations): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 1918
(gdk_window_set_type_hint): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 3395
(gdk_window_set_accept_focus): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 2013
(gdk_window_set_modal_hint): assertion `window != NULL' failed
(:7803): Gtk-CRITICAL **: file gtkwindow.c: line 2529
(gtk_window_realize_icon): assertion `widget->window != NULL' failed
failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 2138
(gdk_window_set_geometry_hints): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 1457
(gdk_window_move): assertion `window != NULL' failed
(:7803): GLib-GObject-CRITICAL **: file gobject.c: line 1561
(g_object_ref): assertion `G_IS_OBJECT (object)' failed
failed
failed
(:7803): Gdk-CRITICAL **: file gdkwindow.c: line 2180
(gdk_window_invalidate_rect): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 1340
(gdk_window_show): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 3942
(gdk_window_unmaximize): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 3826
(gdk_window_unstick): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 3729
(gdk_window_deiconify): assertion `window != NULL' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 4016
(gdk_window_unfullscreen): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 4052
(gdk_window_set_keep_above): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 4093
(gdk_window_set_keep_below): assertion `GDK_IS_WINDOW (window)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow-x11.c: line 1360
(gdk_window_hide): assertion `window != NULL' failed
(:7803): Gtk-CRITICAL **: file gtkstyle.c: line 910 (gtk_style_detach):
(:7803): GLib-GObject-CRITICAL **: file gobject.c: line 1579
(g_object_unref): assertion `G_IS_OBJECT (object)' failed
(:7803): Gdk-CRITICAL **: file gdkwindow.c: line 325
(_gdk_window_destroy_hierarchy): assertion `window != NULL' failed
(eclipse:7801): Gtk-CRITICAL **: file gtksettings.c: line 447
(gtk_settings_get_for_screen): assertion `GDK_IS_SCREEN (screen)' failed
(eclipse:7801): GLib-GObject-CRITICAL **: file gobject.c: line 1222
(g_object_get): assertion `G_IS_OBJECT (object)' failed
(eclipse:7801): GLib-GObject-WARNING **: value "TRUE" of type `gboolean'
is invalid or out of range for property `visible' of type `gboolean'
(eclipse:7801): Gtk-WARNING **: Screen for GtkWindow not set; you must
always set
(eclipse:7801): Gdk-CRITICAL **: file gdkpango-x11.c: line 49
(gdk_pango_context_get_for_screen): assertion `GDK_IS_SCREEN (screen)'
failed
(eclipse:7801): Gdk-CRITICAL **: file gdkscreen-x11.c: line 250
failed
(eclipse:7801): Gdk-CRITICAL **: file gdkpango.c: line 150
(gdk_pango_context_set_colormap): assertion `context != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-context.c: line 382
(pango_context_set_base_dir): assertion `context != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-context.c: line 308
(pango_context_set_font_description): assertion `context != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-context.c: line 343
(pango_context_set_language): assertion `context != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 208
(pango_layout_new): assertion `context != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 782
(pango_layout_set_text): assertion `layout != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 441
(pango_layout_set_attributes): assertion `layout != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 605
(pango_layout_set_alignment): assertion `layout != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 293
(pango_layout_set_width): assertion `layout != NULL' failed
** (eclipse:7801): CRITICAL **: file pango-layout.c: line 2126
(pango_layout_get_extents): assertion `layout != NULL' failed
(eclipse:7801): Gtk-CRITICAL **: file gtkicontheme.c: line 310
(gtk_icon_theme_get_for_screen): assertion `GDK_IS_SCREEN (screen)' failed
(eclipse:7801): Gtk-CRITICAL **: file gtkiconfactory.c: line 1098
(gtk_icon_size_lookup_for_settings): assertion `GTK_IS_SETTINGS
(settings)' failed
(eclipse:7801): Gtk-WARNING **: Invalid icon size 6
(eclipse:7801): Gtk-CRITICAL **: file gtkicontheme.c: line 1240
(gtk_icon_theme_load_icon): assertion `GTK_IS_ICON_THEME (icon_theme)'
failed
Segmentation fault
selfrunname 13:23:12 ~/eclipse4/eclipse $
Nagrik
FUDForum. Page generated in 0.07796 seconds
