Home » Modeling » TMF (Xtext) » [newbie] vanilla buckminster headless build fails
[newbie] vanilla buckminster headless build fails [message #1422824] |
Sat, 13 September 2014 12:43 |
Scott Finnie Messages: 94 Registered: October 2011 |
Member |
Trying to get a headless build working using Buckminster per Lorenzo's book. Seems to work OK in eclipse; p2 site builds OK as far as I can tell.
However trying to run from command line fails (log below). From the error messages it looks like it's trying to retrieve kepler components; however I'm running juno. Before I go hacking about in something I've never touched before I'd appreciate any guidance from anyone.
If it is a case of swapping to juno URIs, is there anything/anywhere specific I need to make changes? Environment is xtext 2.7.0/Luna (4.4)/kubuntu 14.04 64 bit.
Also: is Buckminster still the recommended way to build things, or is tycho now preferred?
Scott.
Buildfile: /home/scoot/projects/xtextws/org.flujo.textual.buckminster/build.ant
cleanup:
buckminster:
[echo] IMPORTANT: Populating an empty target platform may took over 10 minutes.
[java] INFO: setpref 'targetPlatformPath=/home/scoot/projects/xtextws/buildroot/target.platform'
[java] INFO: resolve '/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.cquery'
[java] WARNING [0044] : Component request org.eclipse.emf.common:osgi.bundle/[2.9.2.v20131212-0545,2.9.2.v20131212-0545] is in conflict with request org.eclipse.emf.common:osgi.bundle/2.10.0
[java] WARNING [0045] : Component request org.eclipse.emf.ecore:osgi.bundle/[2.9.2.v20131212-0545,2.9.2.v20131212-0545] is in conflict with request org.eclipse.emf.ecore:osgi.bundle/2.10.0
[java] ERROR [0047] : No suitable provider for component org.eclipse.emf.common:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0047] : No suitable provider for component org.eclipse.emf.common:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0047] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0047] : No suitable provider for component org.eclipse.emf.ecore:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0047] : No suitable provider for component org.eclipse.emf.ecore:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0048] : No suitable provider for component org.apache.commons.lang:osgi.bundle/[2.6.0.v201404270220,2.6.0.v201404270220] was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0048] : No suitable provider for component org.apache.commons.lang:osgi.bundle/[2.6.0.v201404270220,2.6.0.v201404270220] was found in searchPath eclipse
[java] ERROR [0048] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] WARNING [0045] : Component request org.eclipse.emf.ecore.xmi:osgi.bundle/[2.9.1.v20131212-0545,2.9.1.v20131212-0545] is in conflict with request org.eclipse.emf.ecore.xmi:osgi.bundle/2.10.0
[java] ERROR [0059] : No suitable provider for component org.objectweb.asm:osgi.bundle/[5.0.1,6.0.0) was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0059] : No suitable provider for component org.objectweb.asm:osgi.bundle/[5.0.1,6.0.0) was found in searchPath eclipse
[java] ERROR [0059] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0066] : No suitable provider for component org.eclipse.emf.ecore.editor:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0066] : No suitable provider for component org.eclipse.emf.ecore.editor:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0066] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0068] : No suitable provider for component org.eclipse.emf.edit:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0068] : No suitable provider for component org.eclipse.emf.edit:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0068] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0069] : No suitable provider for component org.eclipse.emf.codegen:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0069] : No suitable provider for component org.eclipse.emf.codegen:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0069] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0090] : No suitable provider for component org.eclipse.emf.common.ui:osgi.bundle/[2.9.0,3.0.0) was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0090] : No suitable provider for component org.eclipse.emf.common.ui:osgi.bundle/[2.9.0,3.0.0) was found in searchPath eclipse
[java] ERROR [0090] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0079] : No suitable provider for component org.eclipse.emf.ecore.xmi:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0079] : No suitable provider for component org.eclipse.emf.ecore.xmi:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0079] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] WARNING [0045] : Component request org.eclipse.emf.ecore:osgi.bundle/[2.9.2.v20131212-0545,2.9.2.v20131212-0545] is in conflict with request org.eclipse.emf.ecore:osgi.bundle/[2.10.0,3.0.0)
[java] WARNING [0044] : Component request org.eclipse.emf.common:osgi.bundle/[2.9.2.v20131212-0545,2.9.2.v20131212-0545] is in conflict with request org.eclipse.emf.common:osgi.bundle/[2.10.0,3.0.0)
[java] ERROR [0086] : No suitable provider for component org.eclipse.emf.codegen.ecore:osgi.bundle/2.10.0 was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0086] : No suitable provider for component org.eclipse.emf.codegen.ecore:osgi.bundle/2.10.0 was found in searchPath eclipse
[java] ERROR [0086] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0090] : No suitable provider for component org.eclipse.emf.edit:osgi.bundle/[2.10.0,3.0.0) was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0090] : No suitable provider for component org.eclipse.emf.edit:osgi.bundle/[2.10.0,3.0.0) was found in searchPath eclipse
[java] ERROR [0094] : No suitable provider for component org.eclipse.emf.ecore:osgi.bundle/[2.10.0,3.0.0) was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0094] : No suitable provider for component org.eclipse.emf.ecore:osgi.bundle/[2.10.0,3.0.0) was found in searchPath eclipse
[java] ERROR [0094] : Rejecting provider p2({0}[http://download.eclipse.org/releases/kepler]): No component match was found
[java] ERROR [0094] : No suitable provider for component org.eclipse.emf.common:osgi.bundle/[2.10.0,3.0.0) was found in resourceMap file:/home/scoot/projects/xtextws/org.flujo.textual.buckminster/projects-platform.rmap
[java] ERROR [0094] : No suitable provider for component org.eclipse.emf.common:osgi.bundle/[2.10.0,3.0.0) was found in searchPath eclipse
[java] INFO: TAG-ID 0044 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.platform:eclipse.feature$4.3.2.v20140221-1852 -> org.eclipse.rcp:eclipse.feature$4.3.2.v20140221-1700 -> org.eclipse.e4.rcp:eclipse.feature$1.2.2.v20140206-1358 -> org.eclipse.emf.common:eclipse.feature$2.9.2.v20131212-0545
[java] TAG-ID 0045 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.platform:eclipse.feature$4.3.2.v20140221-1852 -> org.eclipse.rcp:eclipse.feature$4.3.2.v20140221-1700 -> org.eclipse.e4.rcp:eclipse.feature$1.2.2.v20140206-1358 -> org.eclipse.emf.ecore:eclipse.feature$2.9.2.v20131212-0545
[java] TAG-ID 0047 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713
[java] TAG-ID 0048 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui:eclipse.feature$2.7.1.v201409090713
[java] TAG-ID 0059 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.runtime:eclipse.feature$2.7.1.v201409090713
[java] TAG-ID 0066 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui.ecore:osgi.bundle$2.7.1.v201409090713
[java] TAG-ID 0068 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.common.types.edit:osgi.bundle$2.7.1.v201409090713
[java] TAG-ID 0069 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtend.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtend.standalone:osgi.bundle$2.7.1.v201409090713
[java] TAG-ID 0079 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.purexbase:osgi.bundle$2.7.1.v201409090713 -> org.eclipse.xtext:osgi.bundle$2.7.1.v201409090713
[java] TAG-ID 0086 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.xtext.ui:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.xtext.ui:osgi.bundle$2.7.1.v201409090713
[java] TAG-ID 0090 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.ui:osgi.bundle$2.7.1.v201409090713 -> org.eclipse.emf.edit.ui:osgi.bundle$2.9.0.v20140203-1126
[java] TAG-ID 0094 = Query for org.flujo.textual.buckminster:buckminster, path: org.flujo.textual.buckminster:buckminster$1.0.0 -> org.eclipse.xtext.sdk:eclipse.feature$2.7.1.v201409090713 -> org.eclipse.xtext.purexbase:osgi.bundle$2.7.1.v201409090713 -> org.eclipse.emf.mwe2.launch:osgi.bundle$2.7.0.v201409021051 -> org.eclipse.emf.mwe2.language:osgi.bundle$2.7.0.v201409021051
[java]
BUILD FAILED
/home/scoot/projects/xtextws/org.flujo.textual.buckminster/build.ant:28: Java returned: 1
Total time: 2 minutes 5 seconds
Re: [newbie] vanilla buckminster headless build fails [message #1423371 is a reply to message #1422824] |
Sun, 14 September 2014 09:44 |
Hi Scott
Yes, instead of Kepler, Luna should be used, otherwise EMF 2.10 cannot
be found; alternatively, if you want to stay with Kepler you should add,
in the projects-platform.rmap, as a second provider in the "xtext"
search path also the EMF release update site.
I think that the Xtext Buckminster wizard could use an update if it
still refers to Kepler.
I'll also try to update the examples of the book (sorry for the delay)
and try to detail the changes in the git repository.
I still prefer Buckminster, but that's only my opinion ;)
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Current Time: Sun May 05 09:58:19 GMT 2024
Powered by FUDForum. Page generated in 0.02906 seconds
