Home » Newcomers » Newcomers » Install sequence for Eclipse?
Install sequence for Eclipse? [message #251847] Wed, 19 March 2008 09:47 Go to next message
Hi All
Thanks to Tom and Walter I have discovered that the problems I have been
experiencing in my last post have been due to my having Eclipse 3.2
installed while running with SWT 3.3.
Looking at the build on my Ubuntu machine I found I had redundant soft
links all over the place with the jave build and so decided the simplest
course was to rebuild the laptop with a fresh install of Ubuntu.
I now have a virgin machine and want to install Eclipse 3.3 and SWT 3.3
and would apreciate any advice I can get on the best way to go about this.
My thoughts are to: -
1) Install a JRE
2) Install Eclipse 3.3
3) Install SWT 3.3
in that order, does that look like a reasonable course to take?
I also need advice on what would be the best JRE to download and install
for this and how to tell if the default install of Ubuntu has already
installed a JRE.
Any advice would be appreciated.
Bradley
Re: Install sequence for Eclipse? [message #251856 is a reply to message #251847] Wed, 19 March 2008 11:30 Go to previous messageGo to next message
Bradley wrote:
> Hi All
> this. My thoughts are to: -
> 1) Install a JRE
> 3) Install SWT 3.3
Sounds right.
> for this
I would go with Sun JDK 1.6. You definitely want a Sun JDK or JRE (not
GCJ, which is the Ubuntu default).
> installed a JRE.
Check out https://help.ubuntu.com/community/EclipseIDE. I found it very
helpful. It has details on how to sort out the JRE/JDK business.
You'll want to follow the "User Installation" instructions for Eclipse,
as the Universe repository has an older version (3.2 rather than 3.3).
/Paul
Re: Install sequence for Eclipse? [message #251871 is a reply to message #251856] Wed, 19 March 2008 12:30 Go to previous messageGo to next message
Paul A. Rubin schrieb:
> Bradley wrote:
>> Hi All
>> been experiencing in my last post have been due to my having Eclipse
>> 3.2 installed while running with SWT 3.3.
>> simplest course was to rebuild the laptop with a fresh install of Ubuntu.
>> 3.3 and would apreciate any advice I can get on the best way to go
>> about this. My thoughts are to: -
>> 1) Install a JRE
>> 3) Install SWT 3.3
You don't need to install SWT-3.3 because it is part of Eclipse 3.3.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Install sequence for Eclipse? [message #251957 is a reply to message #251847] Thu, 20 March 2008 00:29 Go to previous messageGo to next message
> installed a JRE.
I recommend specifying the JVM in eclipse.ini as described here
http://wiki.eclipse.org/Eclipse.ini
Eric
Re: Install sequence for Eclipse? [message #251960 is a reply to message #251957] Thu, 20 March 2008 00:47 Go to previous messageGo to next message
.... and now we know why you've been winning the "Top Newcomer Evangelist".
6 answers in 12 minutes = 1 question in 2 minutes ;-)
Congrats Eric
Eric Rizzo schrieb:
>> install for this and how to tell if the default install of Ubuntu has
>> already installed a JRE.
> Eric
Re: Install sequence for Eclipse? [message #251988 is a reply to message #251856] Thu, 20 March 2008 11:08 Go to previous messageGo to next message
Thanks Paul
Looks like I have a busy weekend ahead of me... :)
Re: Install sequence for Eclipse? [message #251992 is a reply to message #251871] Thu, 20 March 2008 11:09 Go to previous messageGo to next message
Thanks Tom I was sure to have walked straight into that problem!
Re: Install sequence for Eclipse? [message #251995 is a reply to message #251957] Thu, 20 March 2008 11:10 Go to previous messageGo to next message
Thanks Eric I'll do that
Re: Install sequence for Eclipse? [message #252041 is a reply to message #251960] Thu, 20 March 2008 11:11 Go to previous message
Cool, do I get a prize ;)
Previous Topic:How to show file path on mouse hover over a tab in the editor
Next Topic:Thank you everyone
Current Time: Fri Nov 07 04:42:13 EST 2025
Powered by FUDForum. Page generated in 0.16307 seconds
