Home » Archived » XML Schema Definition (XSD) » ResourceSetImpl.getResource exception
ResourceSetImpl.getResource exception [message #24785] |
Mon, 14 July 2003 14:48 |
Originally posted by: uvrook.mail.nnov.ru
I try to load the scheme from my xsd-file which located on hard disk.
I write:
ResourceSet resourceSet = new ResourceSetImpl();
XSDResourceImpl xsdSchemaResource =
(XSDResourceImpl)resourceSet.getResource
(URI.createFileURI("C://XSD//call.xsd"), true);
or
(URI.createURI("file:///C://XSD//call.xsd"), true);
or
(URI.createURI("file:///C:/XSD/call.xsd"), true);
In any case I get the exception:
java.lang.RuntimeException: Cannot create a resource for 'call1.xsd'; a
registered resource factory is needed
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:282)
at xml_generator.parse_xsd$1.getResource(parse_xsd.java:123)
at xml_generator.parse_xsd.traceLoading(parse_xsd.java:149).."
Could you help me, please, what is wrong.
How can I load the scheme into the memory correctly?
Re: ResourceSetImpl.getResource exception [message #24820 is a reply to message #24785] |
Mon, 14 July 2003 16:30 |
--------------5F4CEC2D53B1ACCD5B62F51D
Content-Type: text/plain; charset=us-ascii
Julia,
You haven't registered a parser (as is documented in the working example in
org.eclipse.xsd.test):
public class XSDMainTest // implements IPlatformRunnable
// This is needed because we can't have the following in the plugin.xml
// <extension point = "org.eclipse.emf.extension_parser">
// <parser type="xsd" class="org.eclipse.xsd.util.XSDResourceFactoryImpl"/>
// </extension>
// The com.ibm.etools.xsdmodel plugin, shipped with WSAD, has a conflicting
registration for this.
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd", new
XSDResourceFactoryImpl());
> I write:
> or
> or
> at
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Julia,
<p>You haven't registered a parser (as is documented in the working example
in org.eclipse.xsd.test):
<blockquote><tt>public class XSDMainTest // implements IPlatformRunnable</tt>
<br><tt>{</tt>
<br><tt> {</tt>
<br><tt> // This is needed because we can't have the
following in the plugin.xml</tt>
<br><tt> //</tt>
<br><tt> // <extension point = "org.eclipse.emf.extension_parser"></tt>
<br><tt> // <parser type="xsd"
class="org.eclipse.xsd.util.XSDResourceFactoryImpl"/></tt >
<br><tt> // </extension></tt>
<br><tt> //</tt>
<br><tt> // The com.ibm.etools.xsdmodel plugin, shipped
with WSAD, has a conflicting registration for this.</tt>
<br><tt> //</tt>
<br><tt> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());</tt>
<br><tt> }</tt></blockquote>
Julia wrote:
<blockquote TYPE=CITE> I try to load the scheme from my xsd-file which
<br> I write:
<p> ResourceSet resourceSet = new ResourceSetImpl();
<p> XSDResourceImpl xsdSchemaResource =
<br> (XSDResourceImpl)resourceSet.getResource
<br>
<br> or
<br> (URI.createURI("<a href="file:///C://XSD//call.xsd">file:///C://XSD//call.xsd</a>"),
true);
<br> or
<br> (URI.createURI("<a href="file:///C:/XSD/call.xsd">file:///C:/XSD/call.xsd</a>"),
true);
<br>
<p> In any case I get the exception:
<br>"
<br>java.lang.RuntimeException: Cannot create a resource for 'call1.xsd';
a
<br>registered resource factory is needed
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:282)
<br> at xml_generator.parse_xsd$1.getResource(parse_xsd.java:123)
<br> at xml_generator.parse_xsd.traceLoading(parse_xsd.java:149).."
<p> Could you help me, please, what is wrong.
<br> How can I load the scheme into the memory correctly?
<br> </blockquote>
</html>
--------------5F4CEC2D53B1ACCD5B62F51D--
Re: ResourceSetImpl.getResource exception [message #24854 is a reply to message #24820] |
Tue, 15 July 2003 08:01 |
Ed, many thanks for quick response.
I have fixed this problem, but I have other error now.
I want to load the scheme as in org.eclipse.xsd.test sample:
URI uri;
File file = new File("C:\\xsd\\call1.xsd");
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
// Create a resource set, create a schema resource, and load the main
schema file into it.
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdMainResource = (XSDResourceImpl)
resourceSet.createResource(URI.createURI("*.xsd"));
xsdMainResource.setURI(uri);
xsdMainResource.load(resourceSet.getLoadOptions);
or simpler:
XSDResourceImpl xsdResource =
(XSDResourceImpl)resourceSet.getResource(uri, true);
In both cases the last row throws such exception :
at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 01)
at
org.eclipse.xsd.util.XSDResourceImpl.createEntityResolver(XS DResourceImpl.java:207)
at
org.eclipse.xsd.util.XSDResourceImpl.getDocument(XSDResource Impl.java:179)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:333)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
at xml_generator.parse_xsd.loadScheme(parse_xsd.java:287)
at xml_generator.parse_xsd.<init>(parse_xsd.java:73)
at xml_generator.parse_xsd.main(parse_xsd.java:107)
at
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:707)
at
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2039)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
at
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
at
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
at org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
at
at
at
at
Could you tell me why I don't load the scheme?
I get such exception if I try to load any xsd-scheme.
I have found recently your library. It's realy very impressive!
I'm from Russia, I hope on your help.
Ed Merks wrote:
> Julia,
plugin.xml
> // </extension>
conflicting
> > I write:
> > or
> > or
> > at
Re: ResourceSetImpl.getResource exception [message #24887 is a reply to message #24854] |
Tue, 15 July 2003 10:18 |
--------------B7CB6E68897AC93141F63B26
Julia,
Have you set up your CLASSPATH as instructed in the FAQ:
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/faq.html#install_classpath
> URI uri;
> if (file.isFile())
> else
> Boolean.TRUE);
> or simpler:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Julia,
> plugin.xml
> > // </extension>
> conflicting
> > > I write:
> > > or
> > > or
> > > at
<html>
Julia,
<p>Have you set up your CLASSPATH as instructed in the FAQ:
<blockquote> <a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/faq.html#install_classpath"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/faq.html#install_classpath</a></blockquote>
<p> Ed, many thanks for quick response.
<br> I have fixed this problem, but I have other error now.
<p> I want to load the scheme as in org.eclipse.xsd.test sample:
<p> URI uri;
<br> File file = new File("C:\\xsd\\call1.xsd");
<br> if (file.isFile())
<br> {
<br> uri = URI.createFileURI(file.getCanonicalFile().toString());
<br> }
<br> else
<br> {
<br> uri = URI.createURI(xsdFile);
<br> }
<p> // Create a resource set, create a schema resource,
and load the main
<br> schema file into it.
<br> //
<br> ResourceSet resourceSet = new ResourceSetImpl();
<br> resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
<br>Boolean.TRUE);
<br> XSDResourceImpl xsdMainResource = (XSDResourceImpl)
<br>
<br> xsdMainResource.setURI(uri);
<br> xsdMainResource.load(resourceSet.getLoadOptions);
<p> or simpler:
<br> XSDResourceImpl xsdResource =
<br>(XSDResourceImpl)resourceSet.getResource(uri, true);
<p> In both cases the last row throws such exception :
<p> java.lang.NullPointerException
<br> at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 01)
<br> at
<br> org.eclipse.xsd.util.XSDResourceImpl.createEntityResolver(XS DResourceImpl.java:207)
<br> at
<br> org.eclipse.xsd.util.XSDResourceImpl.getDocument(XSDResource Impl.java:179)
<br> at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:333)
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
<br> at xml_generator.parse_xsd.loadScheme(parse_xsd.java:287)
<br> at xml_generator.parse_xsd.<init>(parse_xsd.java:73)
<br> at xml_generator.parse_xsd.main(parse_xsd.java:107)
<br>java.lang.NullPointerException
<br> at
<br> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:707)
<br> at
<br> org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2039)
<br> at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
<br> at
<br> org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
<br> at
<br> org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
<br> at
<br> org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
<br> at org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
<br> at
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
<br> at
<br> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
<br> at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
<br> at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
<br> at
<br> at
<br> at
<br> at
<p> Could you tell me why I don't load the scheme?
<br> I get such exception if I try to load any xsd-scheme.
<p> I have found recently your library. It's realy very impressive!
<br> I'm from Russia, I hope on your help.
<p>Ed Merks wrote:
<p>> Julia,
<p>> You haven't registered a parser (as is documented in the working example
in
<br>> org.eclipse.xsd.test):
<p>> public class XSDMainTest // implements
IPlatformRunnable
<br>> {
<br>> {
<br>> // This is
<br>plugin.xml
<br>> //
<br>> //
<br>> //
<parser type="xsd"
<br>class="org.eclipse.xsd.util.XSDResourceFactoryImpl"/>
<p>> //
</extension>
<br>> //
<br>> // The com.ibm.etools.xsdmodel
<br>conflicting
<br>> registration for this.
<br>> //
<br>>
<br> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new
<br>> XSDResourceFactoryImpl());
<br>> }
<p>> Julia wrote:
<p>> > I try to load the scheme from my xsd-file which located on
hard disk.
<br>> > I write:
<br>> >
<br>> > ResourceSet resourceSet = new ResourceSetImpl();
<br>> >
<br>> > XSDResourceImpl xsdSchemaResource =
<br>> > (XSDResourceImpl)resourceSet.getResource
<br>> >
<br>> > or
<br>> > (URI.createURI("<a href="file:///C://XSD//call.xsd">file:///C://XSD//call.xsd</a>"),
true);
<br>> > or
<br>> > (URI.createURI("<a href="file:///C:/XSD/call.xsd">file:///C:/XSD/call.xsd</a>"),
true);
<br>> >
<br>> >
<br>> > In any case I get the exception:
<br>> > "
<br>> > java.lang.RuntimeException: Cannot create a resource for 'call1.xsd';
a
<br>> > registered resource factory is needed
<br>> > at
<br>> >
<br>> > at xml_generator.parse_xsd$1.getResource(parse_xsd.java:123)
<br>> > at xml_generator.parse_xsd.traceLoading(parse_xsd.java:149).."
<br>> >
<br>> > Could you help me, please, what is wrong.
<br>> > How can I load the scheme into the memory correctly?
<br>> ></blockquote>
</html>
--------------B7CB6E68897AC93141F63B26--
Re: ResourceSetImpl.getResource exception [message #25045 is a reply to message #24887] |
Tue, 15 July 2003 12:50 |
Ed, many thanks!
Best regards.
Julia
Ed Merks wrote:
> Julia,
> > URI uri;
> > File file = new File("C:\xsd\call1.xsd");
> > if (file.isFile())
> > else
> > Boolean.TRUE);
> > or simpler:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Julia,
in
> > plugin.xml
> > > // </extension>
> > conflicting
new
> > > > I write:
> > > > or
> > > > or
> > > > at
Re: ResourceSetImpl.getResource exception [message #574113 is a reply to message #24785] |
Ed Merks Messages: 33216 Registered: July 2009 |
Julia,
// </extension>
> I write:
> or
> or
> at
<html>
Julia,
<br><tt>{</tt>
<br><tt> {</tt>
<br><tt> //</tt>
<br><tt> //</tt>
<br><tt> //</tt>
<br> I write:
<br>
<br> or
true);
<br> or
true);
<br>
<br>"
a
<br> at
<br> </blockquote>
</html>
Ed Merks
Re: ResourceSetImpl.getResource exception [message #574184 is a reply to message #24820] |
Julia Messages: 85 Registered: July 2009 |
Member |
URI uri;
if (file.isFile())
else
Boolean.TRUE);
or simpler:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Ed Merks wrote:
> Julia,
plugin.xml
> // </extension>
conflicting
> > I write:
> > or
> > or
> > at
Re: ResourceSetImpl.getResource exception [message #574249 is a reply to message #24854] |
Julia,
> URI uri;
> if (file.isFile())
> else
> Boolean.TRUE);
> or simpler:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Julia,
> plugin.xml
> > // </extension>
> conflicting
> > > I write:
> > > or
> > > or
> > > at
<html>
Julia,
<p> URI uri;
<br> {
<br> }
<br> else
<br> {
<br> }
and load the main
<br> //
<br>Boolean.TRUE);
<br>
<p> or simpler:
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<br> at
<p>Ed Merks wrote:
<p>> Julia,
in
IPlatformRunnable
<br>> {
<br>> {
<br>> // This is
<br>plugin.xml
<br>> //
<br>> //
<br>> //
<parser type="xsd"
<p>> //
</extension>
<br>> //
<br>conflicting
<br>> //
<br>>
new
<br>> }
hard disk.
<br>> > I write:
<br>> >
<br>> >
<br>> >
<br>> > or
true);
<br>> > or
true);
<br>> >
<br>> >
<br>> > "
a
<br>> > at
<br>> >
<br>> >
</html>
Ed Merks
Re: ResourceSetImpl.getResource exception [message #574493 is a reply to message #24887] |
Member |
Ed, many thanks!
Best regards.
Julia
Ed Merks wrote:
> Julia,
> > URI uri;
> > if (file.isFile())
> > else
> > Boolean.TRUE);
> > or simpler:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Julia,
in
> > plugin.xml
> > > // </extension>
> > conflicting
new
> > > > I write:
> > > > or
> > > > or
> > > > at
Current Time: Mon Sep 23 05:45:03 GMT 2024
Powered by FUDForum. Page generated in 0.04785 seconds
