Re: xcore, ecore, emf, xtext and maven [message #1421476 is a reply to message #1421046] |
Thu, 11 September 2014 12:16 |
On 11/09/2014 03:03, Richard Melvin wrote:
> I followed Lorenzo Bettini's tutorial (which I can't link to, but Google
> should find) to try to use xcore for defining the underlying EMF model.
> It works as far as exporting the xcore file, and running the mwe2
> workflow within eclipse. But from maven, using the usual
> exec-maven-plugin/Mwe2Launcher approach, it fails when loading the xcore
> file. The exact error message depends on the dependencies supplied to
> exec-maven-plugin, probably the furthest it has got is with:
> org.eclipse.emf.ecore.xcore
> org.eclipse.emf.ecore.xcore.lib
> org.eclipse.emf.codegen.ecore.xtext
> org.eclipse.emf.common
> org.eclipse.xtext.dependencies
> org.eclipse.xtext.xbase
> org.eclipse.xtext.xbase.lib
> org.eclipse.xtext
> org.eclipse.xtext.xtext
> org.eclipse.xtext.common.types
> which gets:
> XtextLinkingDiagnostic: null:33 Couldn't resolve reference to GenBase
> 'BigInteger'
> which presumably has something to do with the ecore::EBigInteger's my
> grammar uses as terminals.
> Does anyone have one of more of:
> a solution
> some documentaiton of what all the different bundles are
> a working example of this kind of thing
> a suggestion for how to investigate further?
Hi Richard
You can run an mwe2 file from maven (using the fornax plug-in), as you
can see here:
https://github.com/LorenzoBettini/xsemantics/blob/master/plugins/it.xsemantics.dsl/src/it/xsemantics/dsl/GenerateXsemanticsModel.mwe2
Note that this also uses de.itemis.xcore2java.XcoreReader originally
written by Christian (you can find that in the sources of the above
project).
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.03324 seconds
