[2.7.0] Guice errors when unit-testing the generator [message #1418850] |
Sun, 07 September 2014 15:06  |
Hi there,
I've just upgraded to 2.7.0 and now get a blocking error when I try and unit-test the generator. The unit tests for the parser and the validator pass with flying colours.
From the generator test:
@Test
def void testMinimalModel(){
val source = readFile("../myDSL.dsl/models/minimalModel.dsl",Charset.defaultCharset())
source.assertCompilesTo(readFile("../myDSL.dsl/models/minimalModel.xml",Charset.defaultCharset()))
Error:
com.google.inject.ConfigurationException: Guice configuration errors:
1) No implementation for org.eclipse.xtend.lib.macro.file.MutableFileSystemSupport was bound.
while locating org.eclipse.xtend.lib.macro.file.MutableFileSystemSupport
for field at org.eclipse.xtext.generator.FileSystemSupportBasedFileSystemAccess.fileSystemSupport(Unknown Source)
while locating com.google.inject.Provider<org.eclipse.xtext.xbase.compiler.RegisteringFileSystemAccess>
for field at org.eclipse.xtext.xbase.compiler.CompilationTestHelper$Result.fileSystemAccessProvider(Unknown Source)
while locating com.google.inject.Provider<org.eclipse.xtext.xbase.compiler.CompilationTestHelper$Result>
for field at org.eclipse.xtext.xbase.compiler.CompilationTestHelper.resultProvider(Unknown Source)
while locating org.eclipse.xtext.xbase.compiler.CompilationTestHelper
for field at roadblock.xtext.ibl.tests.IblGeneratorTests._compilationTestHelper(Unknown Source)
while locating roadblock.xtext.ibl.tests.IblGeneratorTests
1 error
at com.google.inject.internal.InjectorImpl.getMembersInjector(InjectorImpl.java:952)
at com.google.inject.internal.InjectorImpl.getMembersInjector(InjectorImpl.java:957)
at com.google.inject.internal.InjectorImpl.injectMembers(InjectorImpl.java:943)
at org.eclipse.xtext.junit4.XtextRunner.createTest(XtextRunner.java:33)
at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:244)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:241)
at org.eclipse.xtext.junit4.XtextRunner.superMethodBlock(XtextRunner.java:64)
at org.eclipse.xtext.junit4.XtextRunner.methodBlock(XtextRunner.java:44)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
at org.eclipse.jdt.junit4.runtime.patch.JUnit4TestReference.run(JUnit4TestReference.java:42)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
I can run the the project as an Eclipse application without this error. I'm on Juno Version: Juno Service Release 2, Build id: 20130225-0426. I've got nothing left to update.
Any ideas what could be happening here? And how to fix it?
Thank you!
FUDForum. Page generated in 0.05642 seconds
