Extending model, "Not a valid identifier" error [message #1418198] |
Sat, 06 September 2014 17:58 |
Francesco Scialpi Messages: 5 Registered: August 2014 |
if I place the following into my plugin.xml
<modelExtension
id="bpsim.modelExtension.Process"
name="Bpsim Process Extension"
runtimeId="org.example.bpmn2.modeler.bpsim.runtime"
type="Process">
<property name="extensionValues">
<value>
<property name="bPSimData">
<value>
<property
name="scenario">
<value>
<property
name="author">
</property>
</value>
</property>
</value>
</property>
</value>
</property>
</modelExtension>
all seems to work, but I don't get the "author extension".
If I try and valorize the author property, i.e.
<modelExtension
type="Process">
<value>
<value>
<property
name="scenario">
<value>
<property
name="author" value="foo">
</property>
</value>
</property>
</value>
</property>
</value>
</property>
</modelExtension>
I get the following error:
java.lang.IllegalArgumentException: The datatype 'String' is not a valid classifier
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createFromString(EcoreFactoryImpl.java:160)
at org.eclipse.bpmn2.modeler.core.runtime.BaseRuntimeDescriptor.setValueFromString(BaseRuntimeDescriptor.java:122)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.setValue(ModelExtensionDescriptor.java:338)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObject(ModelExtensionDescriptor.java:422)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObjectFromValues(ModelExtensionDescriptor.java:299)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObject(ModelExtensionDescriptor.java:452)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObject(ModelExtensionDescriptor.java:325)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObject(ModelExtensionDescriptor.java:312)
at org.eclipse.bpmn2.modeler.core.runtime.ModelExtensionDescriptor.populateObject(ModelExtensionDescriptor.java:306)
at org.eclipse.bpmn2.modeler.core.model.Bpmn2ModelerFactory.create(Bpmn2ModelerFactory.java:135)
at org.eclipse.bpmn2.modeler.core.ModelHandler.create(ModelHandler.java:960)
at org.eclipse.bpmn2.modeler.core.ModelHandler.create(ModelHandler.java:933)
at org.eclipse.bpmn2.modeler.core.ModelHandler.createProcess(ModelHandler.java:537)
at org.eclipse.bpmn2.modeler.core.ModelHandler$2.doExecute(ModelHandler.java:158)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.graphiti.ui.internal.editor.GFWorkspaceCommandStackImpl.execute(GFWorkspaceCommandStackImpl.java:117)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.bpmn2.modeler.core.ModelHandler.createProcessDiagram(ModelHandler.java:152)
at org.eclipse.bpmn2.modeler.core.ModelHandler.createDiagramType(ModelHandler.java:129)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.importDiagram(BPMN2Editor.java:514)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.access$0(BPMN2Editor.java:502)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor$2.doExecute(BPMN2Editor.java:482)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.graphiti.ui.internal.editor.GFWorkspaceCommandStackImpl.execute(GFWorkspaceCommandStackImpl.java:84)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.setInput(BPMN2Editor.java:479)
at org.eclipse.bpmn2.modeler.ui.editor.DesignEditor.setInput(DesignEditor.java:102)
at org.eclipse.graphiti.ui.editor.DiagramEditor.init(DiagramEditor.java:217)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:383)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:239)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.addPage(BPMN2MultiPageEditor.java:302)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createDesignEditor(BPMN2MultiPageEditor.java:172)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createPages(BPMN2MultiPageEditor.java:151)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:358)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:610)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:322)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1034)
Pelase note that "author" is declared as a String (not EString) in ecore file (referring to xmltypes), but strangely, if I change that to EString, I obtain the same behaviour.
Please help, I am stuck from almost a day.
[Updated on: Sat, 06 September 2014 18:04] Report message to a moderator
Re: Extending model, "Not a valid identifier" error [message #1427016 is a reply to message #1418198] |
Fri, 19 September 2014 15:18 |
Hi Francesco,
Sorry for the late reply, I've been rather busy lately
I'm afraid you'll have to write your own Property Tab class to handle these extension values. In fact, it looks like a lot of what you're trying to do is already being done in the jbpm plugin. Please have a look at org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5.property.SimulationPropertySection and org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5.property.SimulationDetailComposite. The PropertySection class is referenced in the <propertyTab> extension of the jbpm plugin.xml.
HTH,
Bob
FUDForum. Page generated in 0.02683 seconds
