Home » Eclipse Projects » JFace » ComboViewer Horizontal Layout
ComboViewer Horizontal Layout [message #1417368] Fri, 05 September 2014 05:16 Go to next message
i have a problem with a ComboViewer and the layout. The ComboViewer should be large as needed to show the hole content ? I don't want to set the width with the minSize, because the content length can change.
Example:
 import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.jface.viewers.ComboViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class ComboViewerSnippet {
        // get display.
        Display display = new Display();
        Shell shell = new Shell(display);
        shell.setText("ComboViewerSnippet");
        shell.setSize(200, 200);
        shell.setLayout(new FillLayout(SWT.HORIZONTAL));
        Composite composite = new Composite(shell, SWT.NONE);
        composite.setLayout(new GridLayout(2, false));
        new Label(composite, SWT.NONE).setText("Test");
        ComboViewer viewer = new ComboViewer(composite);
        GridDataFactory.fillDefaults().grab(true, false).applyTo(viewer.getControl());
        viewer.add("Loooooooooooooooong Text");
        viewer.add("890ß Text");
        viewer.add("980ß Text");
        viewer.getCombo().select(0);
        new Label(shell, SWT.NONE).setText("New");
        shell.open();
        while (!shell.isDisposed()) {
            if (!display.readAndDispatch()) {
                display.sleep();
Has anyone an idea?
Re: ComboViewer Horizontal Layout [message #1417385 is a reply to message #1417368] Fri, 05 September 2014 05:48 Go to previous messageGo to next message
To fix your problem, you must :
1. Replace GridDataFactory.fillDefaults().grab(true, false).applyTo(viewer.getControl()); by viewer.getCombo().setLayoutData(new GridData(GridData.FILL, GridData.BEGINNING, true, false));
2. Optionnaly : Replace shell.setLayout(new FillLayout(SWT.HORIZONTAL)); by shell.setLayout(new FillLayout(SWT.VERTICAL));
Hussein
Re: ComboViewer Horizontal Layout [message #1417422 is a reply to message #1417385] Fri, 05 September 2014 07:49 Go to previous messageGo to next message
thanks for your reply:
The first option didn't work Sad
The second option is not possible, because is use the ComboViewer normally in a Toolbar and vertical is not possible Wink
Re: ComboViewer Horizontal Layout [message #1429430 is a reply to message #1417422] Tue, 23 September 2014 04:11 Go to previous message
No other ideas?
Previous Topic:Content not displaced in TreeViewer
Next Topic:Need help with Jface in eclipse
Current Time: Tue Sep 23 03:27:43 EDT 2025
Powered by FUDForum. Page generated in 0.05149 seconds
