Home » Archived » BIRT » Problem with scripted datasets with BIRT 2.2
Problem with scripted datasets with BIRT 2.2 [message #250543] Tue, 31 July 2007 10:39 Go to next message
Originally posted by: pascal4362.freenet.de
Until last week I used BIRT 2.1.2 with some scripted datasets to access
data from a JAVA object. This worked fine until I upgraded Eclipse 3.2.2
to 3.3
The new Version brougt BIRT 2.2, and now I can't get my scripted datasets
working. I get the following error (in the dataset preview and in the
"chart->select data" tab):
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.2.0.v200706221
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: ReferenceError: "BirtReportFactory" is
not defined. (DataSet[SuccessDataset].__bm_open#3)
Script source: DataSet[SuccessDataset].__bm_open, line: 1, text:
__bm_open(). See next exception for more information.
Error evaluating Javascript expression. Script engine error:
ReferenceError: "BirtReportFactory" is not defined.
__bm_open()
My "BirtReportFactory" is in the same eclipse project as the report.
When I Import the package with
"importPackage(Packages.x.x.x.reporting);"
(not necessary with 2.1.2) in the open script of the dataset I get another
error:
expression. Script engine error: Java class
"de.epoq.inbound.reporting.BirtReportFactory" has no public instance field
or method named "createReportTable". (DataSet[Data Set].__bm_open#4)
Script source: DataSet[Data Set].__bm_open, line: 1, text:
Error evaluating Javascript expression. Script engine error: Java class
__bm_open()
But I'm sure I have the mentioned public method, because with 2.1.2 all
worked fine.
I hope someone might help me with my little(?) problem.
Re: Problem with scripted datasets with BIRT 2.2 [message #250617 is a reply to message #250543] Tue, 31 July 2007 15:56 Go to previous messageGo to next message
Can you try placing your jar in the scriptlib directory or the
web-inf/lib direcory of the viewer plugin?
Jason
> to 3.3
> datasets working. I get the following error (in the dataset preview and
> in the "chart->select data" tab):
> __bm_open()
> When I Import the package with "importPackage(Packages.x.x.x.reporting);"
> another error:
> field or method named "createReportTable". (DataSet[Data Set].__bm_open#4)
> __bm_open()
> worked fine.
Re: Problem with scripted datasets with BIRT 2.2 [message #250726 is a reply to message #250617] Wed, 01 August 2007 05:49 Go to previous messageGo to next message
Yes, I tried that. Doesn't change anything.
In my WepApplication the report works fine. It's just a problem of the
eclipse plugin. It's especially a problem when I try to create a chart,
because I can't add data to this chart.
Like recommended my report is in the same eclipse project like the class I
try to retrieve data from. Do I have to set some varibales (runpath or so)
anyway?
Re: Problem with scripted datasets with BIRT 2.2 [message #250749 is a reply to message #250726] Wed, 01 August 2007 10:33 Go to previous message
If you add it to the webviewer plugin/lib or /scriptlib directory this
should work. Can you verify that the your classes do not require
additional classes that are not in the directories listed above?
Jason
> I try to retrieve data from. Do I have to set some varibales (runpath or
> so) anyway?
Previous Topic:joint data set with scripted and sql data source
Next Topic:only beautifying reports
Current Time: Tue Oct 28 06:45:02 EDT 2025
Powered by FUDForum. Page generated in 0.08755 seconds
