Home » Archived » Koneki » LDT - How to stop the file tab, showing the full path text?
LDT - How to stop the file tab, showing the full path text? [message #1416859] |
Thu, 18 April 2013 12:42 |
Ian Smithers Messages: 8 Registered: April 2013 |
The text in the file tab shows the full path rather than just the filename. This means if your file is located in: game/someplace/someotherplace/myfile.lua when you open that file in LDT the tab at the top of the editor shows: game.someplace.someotherplace.myfile.lua
It's also left-aligned, so if you have 10 files open, from myfile1.lua to myfile10.lua, all in the same main directory, then your tabs only show: game.somepla...
Meaning to find out which tab is which file, you have to hover over it, until the hover text appears.
Is there any way to disable that? I see in the screenshots on the Koneki website, that their tabs don't show the path, only the filename which is what I want.
Any help appreciated!
~Ian
Re: LDT - How to stop the file tab, showing the full path text? [message #1416871 is a reply to message #1416863] |
Tue, 30 April 2013 00:22 |
Hi Simon,
What if you have a Lua project where you have a structure like:
game/someaidata/someaisubfolders
game/somemodeldata/somemodelsubfolders
game/somesounddata/somesoundsubfolders
game/somemanagers/
If I have open aifile1 located in game/someaidata/someaisubfolders/aifile1.lua the tab at the top of the file open in LDT shows me "game.someaidata..."
Imagine you have are working on 10 files all in the someaisubfolders area of the project, you get 10 tabs with "game.someaidata..."
It makes it very difficult to work. I'm not building my project with LDT, I'm just using LDT as the editor, for it's highlighting and other features. I'm not entirely sure what you are saying in regards to the modules, unless the modules relate 1:1 to the file paths.
Either way though I would just like to not have anything displayed on the tab, or, if it is going to display something, have it be the pertinent data, like the filename. Not the entire path aligned to show only the start of the path.
~Ian
Re: LDT - How to stop the file tab, showing the full path text? [message #1416872 is a reply to message #1416871] |
Tue, 30 April 2013 13:24 |
Simon Bernard Messages: 345 Registered: July 2009 |
I understand your problem and I'm pretty sure you misconfigured your sourcepath (buildpath).
In your sample perhaps the real source folder is not './' but './gamesomeaidata/someaisubfolders/', you see what I mean ?
You say "you are not building your project with LDT", but buildpath is not use to "compile" or "build application", it is used for tooling (building a model of your code to provide tooling).
I will try to explain the sourcepath meaning with an example :
if you have a structure like this :
MyProject
|_ folder1
|_folder2
|_file.lua
1) if you load file.lua with : local file = require 'folder1.folder2.file'
MyProject <- you must set this folder as source folder
|_ folder1
|_folder2
|_file.lua
The editor will show : 'folder1.folder2.file'
2) if you load file.lua with : local file = require 'folder2.file'
MyProject
|_ folder1 <- you set must this folder as source folder
|_folder2
|_file.lua
The editor will show : 'folder2.file'
A well sourcepath/buildpath configuration is when the editor shows the same thing you write when you want to load your file with "require".
> I only see this issue in LDT. Other IDEs simply show the filename.
We decide to show the module name to manage the 'init.lua' use case :
It's an unspoken standard to consider a file 'mymodule/init.lua' as a module called 'mymodule' (This is done by adding '?/init.lua' to luapath).
In this case, If you just display the filename, all modules will have the save name : 'init.lua'.
By experience, we think a module name is short and we don't imagine your problem (perhaps we are wrong... :/)
for the init.lua case :
MyProject
|_folder2
|_init.lua
the editor will show 'folder2'
In all case, If you do not defined sourcefolders, the editor will show only 'filename' (without extension) but you will not have access to all LDT feature.
Hope this is clearer :)
Current Time: Thu Sep 26 13:31:11 GMT 2024
Powered by FUDForum. Page generated in 0.04854 seconds
