| No way to code to make code hinting to work [message #1416723] |
Thu, 01 November 2012 08:35  |
I past 2 days i did try any combination of eclipse and LDT (0.8, 0.9M, standalone, embeded like plugin) and no way to see code hinting to work.
I made my smal EE with just few functions, with one table and with one type. It was not function, so I used directly file in project, I did any kombination of experiment.
BUT it just not function!!!!
this is my xw.api from EE:
e Xml record DOM resource handle
@type #theRecord
Checks validity of record
@function [parent=#theRecord] isValid
@param self
@return #boolean
eXtraWay lua api
This library provides functions for eXtraWay server side scripting
@module xw
Given a package name, it will load it in current runner
TODO: add sintax of package name
@function [parent=#xw] addPackage
@param #string package name.
@return #number
Create theRecord resource, which is xw DOM of record.
@function [parent=#xw] prepareRecord
@param #string xml string to be parsed
@param #string archive name (empty means current)
@return #theRecord
return nil
Pls. help me. It is evident that I miss somthing , I just cant capture what.
Thx in advance Ladislav.
| Re: No way to code to make code hinting to work [message #1416761 is a reply to message #1416730] |
Thu, 20 December 2012 09:01  |
Sry late response :) had project inferno last month, so I had to do other then pleasure with lua :)
Yes there is no api file, it is xw.lua. I called it .api just for post in forum , for to know that it is just api created by documentor, now i'll try remove # from type definition.
thx laco
FUDForum. Page generated in 0.03806 seconds
