Update from built sources [message #1416689] |
Tue, 09 October 2012 14:13  |
I'm beginner in Eclipse and I have difficulties with updating LDT plugin for Exlipse from p2 repository which I have built from sources as described here: http://wiki.eclipse.org/Koneki/LDT/Developer_Area/Building_LDT_from_source. I didn't find any "repository/target/repository" after build process had completed. I have no idea which direcory (or jar-file) I have to add into repository list to install update. I tryed to add features\org.eclipse.koneki.ldt.product-feature\target\site\content.jar but I got error about dependencies
Re: Update from built sources [message #1416691 is a reply to message #1416690] |
Wed, 10 October 2012 00:00   |
Benjamin Cabe wrote on Tue, 09 October 2012 14:17
> Hey Denis,
> You don't have repository/target at all?
"repository/target" is local folders in LDT directory which apears afrer build, right? I have only "repository" root-directory with category.xml and pom.xml files in it and "target-platform" root-directory with ldt.target and pom.xml files.
> Adding features/... should have worked, what are the dependencies that are missing? I would suspect that you are trying to update from 0.8 to "0.9 master"
I tried to update from last 0.9 and I got this message:
> An error occurred while collecting items to be installed
> session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
> No repository found containing: osgi.bundle,com.naef.jnlua,0.9.1.201210091735
> No repository found containing: osgi.bundle,com.naef.jnlua.windows,0.9.1.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.debug.core,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.debug.ui,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.doc.user,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.metalua,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.metalua.32bits,0.9.0.201210091735
> No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.ui,0.9.0.201210091735
> No repository found containing: org.eclipse.update.feature,org.eclipse.koneki.ldt,0.9.0.201210091735
I was wrong before. It is no message about dependencies...
Re: Update from built sources [message #1416695 is a reply to message #1416694] |
Thu, 11 October 2012 01:51   |
Kevin KIN-FOO wrote on Wed, 10 October 2012 13:01
> Yes it is,
> Check the content of features/org.eclipse.koneki.ldt.product-feature/target/site/
This doesn't work for me. It stops with message
> Your original request has been modified.
> "Add-on Function for p2" is already installed, so an update will be performed instead.
> "Dynamic Languages Toolkit - Core Frameworks" is already present because other installed software requires it. It will be added to the installed software list.
> "Eclipse Help System" is already installed, so an update will be performed instead.
> "Eclipse Platform" is already installed, so an update will be performed instead.
> "Eclipse RCP" is already installed, so an update will be performed instead.
> "EMF - Eclipse Modeling Framework Core Runtime" is already installed, so an update will be performed instead.
> "EMF Common" is already installed, so an update will be performed instead.
> "Equinox p2 Core Function" is already installed, so an update will be performed instead.
> "Equinox p2 Provisioning for IDEs." is already installed, so an update will be performed instead.
> "Equinox p2 RCP Management Facilities" is already installed, so an update will be performed instead.
> "Lua Development Tools (Incubation)" is already installed, so an update will be performed instead.
> "Lua Development Tools - branding (Incubation)" is already installed, so an update will be performed instead.
> Cannot complete the install because of a conflicting dependency.
> Software being installed: Eclipse e4 Rich Client Platform 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj (org.eclipse.e4.rcp.feature.group 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj)
> Software currently installed: Lua Development Tools Product (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product-product 0.9.0.201210101448)
> Only one of the following can be installed at once:
> Simple Configurator 1.0.200.v20110815-1438 (org.eclipse.equinox.simpleconfigurator 1.0.200.v20110815-1438)
> Simple Configurator 1.0.301.v20120828-033635 (org.eclipse.equinox.simpleconfigurator 1.0.301.v20120828-033635)
> Simple Configurator 1.0.300.v20110815-1744 (org.eclipse.equinox.simpleconfigurator 1.0.300.v20110815-1744)
> Cannot satisfy dependency:
> From: Eclipse e4 Rich Client Platform 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj (org.eclipse.e4.rcp.feature.group 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj)
> To: org.eclipse.equinox.simpleconfigurator [1.0.301.v20120828-033635]
> From: Lua Development Tools Product (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product-product 0.9.0.201210101448)
> To: org.eclipse.koneki.ldt.product.feature.group [0.9.0.201210101448]
> From: Lua Development Tools - branding (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product.feature.group 0.9.0.201210101448)
> To: org.eclipse.platform.feature.group [3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q]
> From: Eclipse Platform 3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q (org.eclipse.platform.feature.group 3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q)
> To: org.eclipse.rcp.feature.group [3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272]
> From: Eclipse RCP 3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272 (org.eclipse.rcp.feature.group 3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272)
> To: org.eclipse.equinox.simpleconfigurator [1.0.200.v20110815-1438]
FUDForum. Page generated in 0.04919 seconds
