Home » Archived » Koneki » About code assistant.
About code assistant. [message #1416531] Thu, 19 July 2012 19:27 Go to next message
HI.
i'm using standalone last version tool.
i'm testing about OUTLINE window and CODE_ASSISTANT.
At outline it display only first level items(table, function) and table's field is not display. (it's right? will be update?)
At code assistant. it display global items(table, function) only, and i can't open member list window with '.' access(ex ctrl+space)
are this problems current version's limitation or my fault?
Re: About code assistant. [message #1416543 is a reply to message #1416531] Fri, 27 July 2012 09:04 Go to previous message
In the last http://eclipse.org/koneki/ldt/#installation (0.8):
The outline display only the first level local variable and the API you could describe with http://wiki.eclipse.org/Koneki/LDT/Technical_Documentation/Documentation_Language.
The should have content assist :
- on local variables.
- on global variables considered as preloaded in your execution environment. (like print in lua 5.1)
- on module documented with luadocumentor.
Did you try the execution environment feature ?
You could http://sierrawireless.github.com/lua-execution-environments/ and http://wiki.eclipse.org/Koneki/LDT/User_Guide#Execution_Environment the Lua 5.1 execution environment support to your project to enable autocompletion for lua 5.1.
HTH
Previous Topic:folding not working
Next Topic:Code Assistance for external lib
Current Time: Sun Nov 09 21:30:54 EST 2025
Powered by FUDForum. Page generated in 0.03513 seconds
