Re: Deploy test resource to Tomcat Server [message #1417265 is a reply to message #1416491] |
Fri, 05 September 2014 03:42 |
On 09/04/2014 04:13 PM, Mark Beierl wrote:
> I have a Maven war project that I can run in Eclipse by deploying it to
> a Tomcat server. This works fine for developing and debugging, but I
> also have a test.xml resource file that I would like to deploy to my
> webapp when I debug it. I do not want this test.xml file to end up in
> the final war though.
> So:
> 1) If I put the test.xml file into src/main/webapp/WEB-INF, it is
> included in the war file and as a result is visible when debugging.
> 2) If I put the test.xml file into src/test/resources, or
> src/test/webapp/WEB-INF, it is not deployed to tomcat on debug, and
> therefore not visible.
> Can this be done, or is there another way to go about this?
First, this is a question for the Eclipse Web Tools Platform forum,
however, let me see if I can confuse you more before you go there...
When I put such a file on a path such as src/test/resources/test.xml, I
do indeed see it when running Tomcat from within Eclipse. I would expect
to see it on a path very similar to:
<workspace>/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/<project>/resources/test.xml.
When the WAR is built, I would not expect to see it in the final product
unless you specifically ask for src/test/resources stuff to get put there.
I hope this helps.
FUDForum. Page generated in 0.08172 seconds
