Home » Archived » Koneki » Debugging lualatex
Debugging lualatex [message #1416430] Wed, 16 May 2012 03:38 Go to next message
Lualatex uses lua as a scripting engine. I develop all my lua code separately then add it in to lua because it is difficult to debug(have to use console printing).
By using the debugger scripts for the DBGT will/should it hook into the ldt and allow breakpoints and inspection?
Re: Debugging lualatex [message #1416436 is a reply to message #1416430] Wed, 16 May 2012 15:56 Go to previous messageGo to next message
After a quick search on the Internet, it seems that LuaLatex somehow supports/includes Luasocket, which is needed by the DBGP client. So I guess you should be able to use it in the exact same way you would use it in a regular Lua script... Let us know the outcome!
Re: Debugging lualatex [message #1416438 is a reply to message #1416436] Thu, 17 May 2012 04:32 Go to previous messageGo to next message
The issue I get with the following test is:
"LuaSocket 2.0.2
test.tex:8: LuaTeX error debugger.lua:68: module 'socket' not found:
no field package.preload['socket']
[kpse lua searcher] file not found: 'socket'
[kpse C searcher] file not found: 'socket'
stack traceback:"
with the following code(DebugTest.lua):
socket = require("socket")
print("\n"..socket._VERSION.."\n")
require("debugger")()
Line 68 in debugger is
local socketcore = require"socket.core"
and I've tried changing it to
local socketcore = require"socket"
but get the same error.
I then copied core.dll and socket.lua from my main lua distro so that lualatex could find it(same dir as my lua code). This got past that error. (I don't know why the first line worked and printed version though... should be the exact same stuff?)
Next I got an error in base_path:
"156: if not base_dir then error("Unable to determine the working directory.")end"
which I just hard coded the base_dir to the source code files.
When I ran for the first time I got a timeout trying to access the debugger. When I started the DGBT and ran everything worked BUT the breakpoints were not hit. Subsequently running the tex program without DGBT running did not cause it to time out but printed debugger_loop error msg that generally happens in LDT.
So the only real issue is getting the breakpoints working. Any ideas?
Re: Debugging lualatex [message #1416515 is a reply to message #1416438] Sun, 15 July 2012 11:00 Go to previous messageGo to next message
I have now been able to succesfully debug lua code from a lualatex!!!!!!!!!!!!!!
Simply include the standard require debugger header in your tex(or lua code)
\directlua{require("debugger")()}
Add your breakpoints, start the debugger in the ldt, then compile the tex code. This should be a great boon for lualatex. It seems the recent updates have solved the problem(as I have done nothing different since the I posted these messages).
Re: Debugging lualatex [message #1416516 is a reply to message #1416515] Sun, 15 July 2012 12:05 Go to previous messageGo to next message
w00t! That's great news!
Re: Debugging lualatex [message #1416518 is a reply to message #1416516] Sun, 15 July 2012 18:52 Go to previous message
One issue seems to be the that one can't load external lua files and debug them. Trying to add a breakpoint to a lua file not in the project results in a null breakpoint added. (Well, normally it is Lua: <filename> [line: <line>] but in this case filename is shown as null which suggests it has an issue dealing with files)
Previous Topic:Keep debugger running
Next Topic:I want customize code
Current Time: Thu Nov 06 09:09:44 EST 2025
Powered by FUDForum. Page generated in 0.05640 seconds
