Obfuscated version doesn't run [message #24637] |
Thu, 01 January 2009 17:31  |
Originally posted by: news.s237965939.online.de
I'm using ProGuard, but when I doubleclick the .jad file and press
"launch" the application terminates with these messages. Does anyone
know this problem and has a solution?
Running with storage root C:\Documents and
Settings\Hajue\j2mewtk\2.5.2\appdb\Hajue
Running with locale: German_Germany.1252
Running in the identified_third_party security domain
Error verifying method MobileGuitarMIDlet startApp()V
Approximate bytecode offset 0: Inconsistent or missing stackmap at target
Method............: 10233084
'com/sun/midp/midlet/MIDletState.createMIDlet (static)'
TIA,
Hans
Re: Obfuscated version doesn't run [message #25102 is a reply to message #25062] |
Sat, 10 January 2009 13:22  |
Craig Setera wrote:
> MyProgram_obf.jar is the jar that is obfuscated, but not yet preverified
> since being obfuscated. MyProgram.jar is both obfuscated and
> preverified. Because obfuscation alters the JAR's code, it is necessary
> to preverify the JAR file again.
> In general, you should avoid playing too much with the JAD pointers to
> the JAR files.
Thanks for the info, Craig. It was very helpful for me since I'm still
learning all tat J2ME stuff. And thanks for the answer to my OTA
question in the other thread too.
Hans
Re: Obfuscated version doesn't run [message #569618 is a reply to message #24637] |
Thu, 01 January 2009 18:34  |
I forgot to mention that if I load the obfuscated .jar into a
decompiler, it shows errors here and there. But not in startApp as
listed above.
Hans
Re: Obfuscated version doesn't run [message #569668 is a reply to message #24637] |
Fri, 02 January 2009 12:08  |
Sorry, my fault. There is no problem. In the deployed folder there are 3
files created. MyProgram.jad, MyProgram.jar and MyProgram_obf.jar.
Only when I edit the jad to refer to MyProgram_obf.jar I get that error.
I thought MyProgram.jar would be the unobfuscated package but it's
obfuscated too. Now I'm just wondering why two JARs are generated.
Hans
Re: Obfuscated version doesn't run [message #569857 is a reply to message #24756] |
Thu, 08 January 2009 20:08  |
the JAR files.
Craig
> Hans
Re: Obfuscated version doesn't run [message #569887 is a reply to message #25062] |
> the JAR files.
Hans
FUDForum. Page generated in 0.03921 seconds
