Home » Newcomers » Newcomers » Cant add .jar to target plattform
Cant add .jar to target plattform [message #1414498] Sun, 31 August 2014 09:53 Go to next message
Hello everybody!
I'm trying to add the new xtend lib (2.62) to my target plattform.
I downloaded the .jar files (xtend.lib,xbase.lib), and copied them (within eclipse) into a subfolder (plugins) of my active target plattform.
But when I go to Window -> Pref. -> Plugin Dev. -> target plattform (choosing then edit, with the correct plattform marked) I cant find the new xtend lib (only the old one, 2.31 wich was there before).
What else do I have to do? (Refreshenig all projects or restarting eclipse does not work).
One xtend Template I wanted to use says "Add xtend libs to classpath" as quickfix (clicking it does not work...)
Re: Cant add .jar to target plattform [message #1414516 is a reply to message #1414498] Sun, 31 August 2014 11:07 Go to previous messageGo to next message
On 08/31/2014 07:53 AM, alloisxp alloisxp wrote:
> Hello everybody!
What goes in the plugin subdirectory under Eclipse is plug-in tools for
Eclipse.
JARs don't go in your plug-in folder. I'm not a plug-in developer, but I
think you want them somewhere in your project because you're using them
to develop software not run Eclipse itself, right?
Re: Cant add .jar to target plattform [message #1414771 is a reply to message #1414516] Mon, 01 September 2014 05:19 Go to previous messageGo to next message
Thanks for your answer!
Im new to plugin-dev too, but I thought the concept of the target-plattform means a collection of plugins that are usable by your plugin-project when you point to this target plattform.
So I thought when I copy a .jar file into this target plattform folder its like copying a .jar into a classpath (in standard java projects)?
Is there something else I have to do? (he does not find the new xtend lib when I want to add it under dependencys for a plugin, only the old lib, but the jar files are in the same folder... ?? Im confused...)
Re: Cant add .jar to target plattform [message #1414915 is a reply to message #1414771] Mon, 01 September 2014 11:44 Go to previous messageGo to next message
Some brighter Crayon than I should be along soon, perhaps tomorrow if
not today, which is a US holiday.
Re: Cant add .jar to target plattform [message #1415728 is a reply to message #1414771] Wed, 03 September 2014 09:27 Go to previous messageGo to next message
the target platform is based on installed bundles, thus, just copying
..jar is not enough, as far as I know...
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Cant add .jar to target plattform [message #1416173 is a reply to message #1415728] Thu, 04 September 2014 09:30 Go to previous messageGo to next message
hm ok, so somehow I must install xtend to the target plattform. How do I do that if not by copying the runtime librarie jars into the target platform?
Im trying to get this fixed for a week now. Sad
Re: Cant add .jar to target plattform [message #1416271 is a reply to message #1416173] Thu, 04 September 2014 14:26 Go to previous messageGo to next message
You might try posting your question in the Plugin Development Environment (PDE) forum.
Re: Cant add .jar to target plattform [message #1422692 is a reply to message #1416173] Sat, 13 September 2014 03:43 Go to previous message
> platform?
> Im trying to get this fixed for a week now. :(
You can use a .target definition file.
Xtext Book:
Previous Topic:Jetty 9.2.3 java.util.concurrent.TimeoutException
Next Topic:Re: Eclipse plugin development - Custom Wizard for New C++ project
Current Time: Sun Sep 14 15:34:11 EDT 2025
Powered by FUDForum. Page generated in 0.09788 seconds
