Home » Language IDEs » Java Development Tools (JDT) » Search for preference function does not work under some situation
Search for preference function does not work under some situation [message #250067] Thu, 06 December 2007 17:09 Go to next message
Originally posted by: ku_long.hotmail.com
Hey,
I don't know if anyone has encountered the same problem as me.
Our plug-in imported a jar file to which a source jar was attached.
In my code, I refered to some class in that jar. When I used "Open
Declaration" function to open the class, I got the souce code
opened in an editor (the title is ***.class). Then, I tried to
use "Search for preferences" function to search the prefernces of
a variable; zero result was returned. But if I open the java file
of that class manually and do "Search for preferences" on the
same variable, I got the proper results. I have no idea with this
behavior.
Thanks.
Re: Search for preference function does not work under some situation [message #250098 is a reply to message #250067] Sat, 08 December 2007 14:31 Go to previous messageGo to next message
Raymond wrote:
> Hey,
> Declaration" function to open the class, I got the souce code opened in
> use "Search for preferences" function to search the prefernces of a
> variable; zero result was returned. But if I open the java file of that
> class manually and do "Search for preferences" on the same variable, I
> behavior.
> Thanks.
I guess you meant "Search for References"...
What kind of variable did you search for (local variable, method
parameter or perhaps field)? How did you launch the search: using a menu
item or using the Java Search page?
Re: Search for preference function does not work under some situation [message #250138 is a reply to message #250098] Mon, 10 December 2007 15:19 Go to previous messageGo to next message
Yes, I meant "Search for Reference". :-)
I searched for local variables, fields and method.
I launched the search by typing "Ctrl + Shift + G" to launch
the Type search dialog.
Thanks.
Re: Search for preference function does not work under some situation [message #250152 is a reply to message #250138] Tue, 11 December 2007 04:14 Go to previous message
> I searched for local variables, fields and method. I launched the search
> by typing "Ctrl + Shift + G" to launch the Type search dialog.
> Thanks.
Hmm, perhaps you discovered a problem in JDT/Core Search Engine. So, please
open a bug against the JDT/Core component providing a simple test case to
reproduce your problem, thanks
Previous Topic:Creating sample projects.
Next Topic:Programmatically adding projects to the standard source lookup
Current Time: Sat Sep 27 07:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.03613 seconds
