Home » Modeling » Epsilon » [ECL] Problems with recursive permutation of items in collections acc. to Fike algorithm
| [ECL] Problems with recursive permutation of items in collections acc. to Fike algorithm [message #1413733] |
Fri, 29 August 2014 05:47  |
Hi all,
I am trying to implement a recursive permutation algorithm according to Fike in ECL. I would like to permute the items of a collection (sequence). However, I do not really know how to replace an item of a collection. In the following, I provide the code excerpt of my ECL module that deals with this issue. The collection looks like the following:
g_pbs_collection_to_permute: Sequence {Class 2.method, Class1.method, Class 2.attribute1, Class1.attribute1}
var arrZahlen : Sequence;
var intAnzahl : Integer;
var strOut : String;
intAnzahl = 4;
arrZahlen = g_pbs_collection_to_permute;
nextPermutation(1);
operation nextPermutation( intI : Integer ){
var intHelp : String;
var i : Integer;
// Rekursive determination of all permutations of a set of with size intAnzahl
i = intI;
while ( i < intAnzahl ){
// Exchange the current position with the given position
intHelp = arrZahlen.at(i);
arrZahlen.remove(i);
arrZahlen.add(i, arrZahlen.at(intI));
arrZahlen.remove(intI);
arrZahlen.add(intI, intHelp);
// If the end of the set has not been reached
if (intI < intAnzahl-1){
nextPermutation(intI + 1);
else{
("Permutation: "+arrZahlen).println();
// Reverse the exchange again
i = i + 1;
I suppose that the following statements are wrong and do not really work:
I suppose the preceeding statements do not work, as I get the following result list:
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
Permutation: Sequence {Class 2.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class1.method, Class 2.attribute1, Class1.attribute1}
I very much appreciate any hints how to fix my problem.
Thanks a lot in advance and kind regards, Alexander
| Re: [ECL] Problems with recursive permutation of items in collections acc. to Fike algorithm [message #1415653 is a reply to message #1415418] |
Wed, 03 September 2014 05:30   |
Hi Dimitris,
many thanks for your quick reply and your solution proposal. I adjusted the code accordingly. However, now I get an error, see:
This is the minimal example for the problem with permutation of Collection items.
Number of <<ProblemBearing>> Dependencies in left model: 4
Number of <<ProblemBearing>> Dependencies in right model: 2
Warning: The type 'Dependency' is ambiguous and could refer to any of the following: 'Left!Dependency' 'Right!Dependency'. The type 'Left!Dependency' has been assumed.
Number Operation supplier type in left PCP: 2
Number Property supplier type in left PCP: 2
Number Class supplier type in left PCP: 0
Number Operation supplier type in right PCP: 2
Number Property supplier type in right PCP: 0
Number Class supplier type in right PCP: 0
g_num_of_mapping_elements: 4
This is the list of elements/items in the set/collection that need to be permuted: Sequence {Class2.method, Class1.method, Class1.attribute1, Class2.attribute1}
Start of permutation
l_i: 1
l_intHelp: Class1.method
g_arrZahlen.at(l_i): Class1.method
intI: 1
l_i: 2
l_intHelp: Class1.attribute1
g_arrZahlen.at(l_i): Class1.attribute1
intI: 2
l_i: 3
l_intHelp: Class2.attribute1
g_arrZahlen.at(l_i): Class2.attribute1
intI: 3
Internal error: java.lang.IndexOutOfBoundsException: Index: 3, Size: 3
at java.util.ArrayList.rangeCheck[Unknown Source]
at java.util.ArrayList.get[Unknown Source]
at org.eclipse.epsilon.eol.execute.operations.contributors.IterableOperationContributor.at[IterableOperationContributor.java:92]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
at java.lang.reflect.Method.invoke[Unknown Source]
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[ReflectionUtil.java:187]
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[ReflectionUtil.java:163]
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation[PointExecutor.java:174]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:89]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:49]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:104]
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[ExecutorFactory.java:190]
at org.eclipse.epsilon.eol.execute.ParametersExecutor.execute[ParametersExecutor.java:29]
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation[PointExecutor.java:151]
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[ExecutorFactory.java:160]
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execute[StatementBlockExecutor.java:26]
at org.eclipse.epsilon.eol.execute.WhileStatementExecutor.execute[WhileStatementExecutor.java:52]
at org.eclipse.epsilon.eol.EolOperation.executeBody[EolOperation.java:276]
at org.eclipse.epsilon.eol.EolOperation.execute[EolOperation.java:248]
at org.eclipse.epsilon.eol.EolOperation.execute[EolOperation.java:206]
at org.eclipse.epsilon.eol.EolOperations.execute[EolOperations.java:119]
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation[PointExecutor.java:157]
at org.eclipse.epsilon.eol.execute.ContextlessOperationExecutor.execute[ContextlessOperationExecutor.java:27]
at org.eclipse.epsilon.eol.execute.NameExecutor.execute[NameExecutor.java:38]
at org.eclipse.epsilon.eol.execute.NameExecutor.execute[NameExecutor.java:97]
at org.eclipse.epsilon.eol.execute.IfStatementExecutor.execute[IfStatementExecutor.java:43]
at org.eclipse.epsilon.erl.ErlModule.execute[ErlModule.java:88]
at org.eclipse.epsilon.ecl.EclModule.execute[EclModule.java:115]
at org.eclipse.epsilon.eol.dt.launching.EpsilonLaunchConfigurationDelegate.launch[EpsilonLaunchConfigurationDelegate.java:79]
at org.eclipse.epsilon.eol.dt.launching.EpsilonLaunchConfigurationDelegate.launch[EpsilonLaunchConfigurationDelegate.java:56]
at org.eclipse.debug.internal.core.LaunchConfiguration.launch[LaunchConfiguration.java:858]
at org.eclipse.debug.internal.core.LaunchConfiguration.launch[LaunchConfiguration.java:707]
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch[DebugUIPlugin.java:1018]
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run[DebugUIPlugin.java:1222]
at org.eclipse.core.internal.jobs.Worker.run[Worker.java:53]
(D:\Eclipse\Workspace1\ProPMan Development\MinimalExample for ECL problems with recursive permutation of items in collections using Fike algorithm\MinimalExample_ProPRet_PCP2PCP_Comparator_GraphMatchingTests.ecl@186:42)
I understand that it has to do with the array index. If I start with the index 0 ("next_permutation(0)") and the g_intAnzahl = 3, then no error occurs, but only 3 items of the collection are permuted, the fourth item is just added on the 4th place. I was not able to analyze the cause for this problem.
It would be great if you had a proposal for a change that makes it work.
Please note that I also added some println() lines to debug. I attached the current project file.
Current Time: Fri Nov 07 13:38:43 EST 2025
Powered by FUDForum. Page generated in 0.04885 seconds
