Ctrl+Breakon eclipse launched java program [message #249764] |
Fri, 23 November 2007 15:43 |
Originally posted by: none.domain.invalid
is there a way to type Ctrl+Break for a java Application started from
eclipse ?
Trying to type it in the console didn't work for me.
Many thanks
Re: Ctrl+Breakon eclipse launched java program [message #249775 is a reply to message #249771] |
Fri, 23 November 2007 16:16 |
Daniel Megert a écrit :
> Name wrote:
>> eclipse ?
> Use eclipsec.exe
I'm not talking about a threa dump of eclipse, but a thread dump of my
java application launched from "inside" eclipse!
The most likely thing i can do is pausing the application in the "Debug"
view, and copying the stack trace...
Re: Ctrl+Breakon eclipse launched java program [message #249803 is a reply to message #249781] |
Mon, 26 November 2007 09:07 |
Ashkan a écrit :
>>> Name wrote:
>>>> Hi,
>>>> from eclipse ?
>>> Use eclipsec.exe
>> "Debug" view, and copying the stack trace...
> Just kill the process in console view. Or am I missing your point? :-?
Well, killing the process doens't generate a thread dump. I've done it
several times. If you are missing my point, i say it again: let's say my
java application (developped with eclipse and launched from eclipse),
freeze somewhere, i would like to know where, and i need a thrund dump.
Re: Ctrl+Breakon eclipse launched java program [message #249815 is a reply to message #249807] |
Mon, 26 November 2007 10:53 |
>>> Name wrote:
>>>> Hi,
>>>> from eclipse ?
>>> Use eclipsec.exe
> That's the only way out of Eclipse. There's a tool that allows you get a
> trace from the outside (http://www.adaptj.com/root/main/stacktrace).
Thnaks !!
FUDForum. Page generated in 0.04216 seconds
