Re: Custom XML model editor [message #1413844 is a reply to message #1413352] |
Fri, 29 August 2014 15:09 |
Le 28/08/2014 14:18, Oscar Castro a écrit :
> It's possible to edit a custom XML data file with an editor generated
> with Sirius?
> I mean, the XML does not conform the XMI spec but I built a model with
> the XSD based model generator available on EMF to build the model, edit
> and editor plugins.
If you have generated the model, edit and editor plugins, they should
declare your metamodel and contain a resource factory able to load your
models.
So Sirius should be able to load it.
> Thanks.
Maxime - Obeo
Need professional services for Sirius?
Maxime Porhel - Obeo
FUDForum. Page generated in 0.04190 seconds
