Re: [CDO] Delete values from version history [message #1412794 is a reply to message #1412612] |
Wed, 27 August 2014 04:44 |
Am 26.08.2014 um 17:39 schrieb Ruben Faelens:
> Thank you for the explanation.
> I would be happy if I could just NULL the 'contents' feature of my CDOObject. That could be done with a simple SQL query:
> UPDATE SimulationOutput SET output='' WHERE cdoId IN (SELECT cdoId FROM SimulationOutput WHERE deleted=TRUE)
> (pseudo-code)
If you're absolutely sure that no other object (that doesn't get deleted at the same time) refers to the deleted objects
(at any time) it seems okay to me. Otherwise Esteban's suggestion is a little cleaner but probably not much safer
because referential integrity is not enforced for CDO's external references either.
> Another option would be to never store this specific feature in the DB. Would this be another way?
Of course you can set the respective features in your model to transient or add a CDO-specific annotation to set CDO
transient-ness independent of EMF's standard property.
> Immediately splitting my model over two repositories and requiring XA Transactions seems like a lot of refactoring...
I guess that would make more sense if atomicity isn't strictly needed across the repos.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
FUDForum. Page generated in 0.02543 seconds
