Unable to put a bordered node inside the node (in Diagram) [message #1412125] |
Mon, 25 August 2014 10:51 |
Eclipse Guest Messages: 93 Registered: February 2013 Location: Vienna |
Member |
I tried to follow some tutorials for Sirius but I didn´t get a bordered node into the node and I don´t see my mistake.(See attached Screenshot)
So what I want is Intake,TurnLeft and Lift (Bordered ComponentOperation) inside Crane (Component). At the moment I can only move these blocks around the upper block Crane.
Can someone help me?
Re: Unable to put a bordered node inside the node (in Diagram) [message #1412168 is a reply to message #1412125] |
Mon, 25 August 2014 13:07 |
I'm not sure to understand your problem, but border node has to be at
the border of its parent. If you want a node inside a container, it is
not a border node but simply a node.
But for that, Component should be a Container (and not a Node as in your
screenshot).
Laurent - Obeo
Need professional services for Sirius?
Laurent Redor - Obeo
FUDForum. Page generated in 0.05890 seconds
