Home » Eclipse Projects » e(fx)clipse » Embedding JavaFX in SWT E4 RCP application doesn't work(FXViewPart is empty and FXCanvas class can't even be found)
Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411098] |
Fri, 22 August 2014 11:34 |
Philippe S Messages: 2 Registered: August 2014 |
I have an E4 RCP application using SWT, built with Eclipse Luna and running on Debian 7.6 64-bit. My goal is to embed JavaFX into this application.
I downloaded JDK 8 from the Oracle site, unzipped it, provided the path to the -vm parameter in eclipse.ini, added it to the installed JREs in Eclipse and set it for my application plug-in and product.
I added e(fx)clipse from http://download.eclipse.org/efxclipse/updates-released/1.0.0/site to my Luna installation, selecting all items. I also added "RCP 3.x Target Platform" and "Target Platform" from http://download.eclipse.org/efxclipse/runtime-nightly/site to the target platform.
I added the following plug-ins to the dependencies:
- org.eclipse.fx.ui.workbench3
- org.eclipse.fx.javafx
And the following features to the product:
- org.eclipse.fx.target.rcp.feature
- org.eclipse.rcp
Based on e(fx)clipse tutorial no. 2, I added -Dosgi.framework.extensions=org.eclipse.fx.osgi to the VM arguments and the following part to my part stack:
import javafx.scene.Scene;
import javafx.scene.control.Button;
import javafx.scene.layout.BorderPane;
import org.eclipse.fx.ui.workbench3.FXViewPart;
public class JavaFxPart extends FXViewPart {
private Button button;
protected Scene createFxScene() {
BorderPane pane = new BorderPane();
button = new Button("test");
pane.setCenter(button);
return new Scene(pane);
protected void setFxFocus() {
button.requestFocus();
However, that part doesn't display anything. Debugging also shows that createFxScene is not entered.
Alternatively, I tried to use FXCanvas (wouldn't it be better anyway to use this instead of a view part based on E3?), but the class can't be found.
What am I doing wrong?
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411138 is a reply to message #1411098] |
Fri, 22 August 2014 13:41 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
On FXViewPart:
First of all is the application you develop a pure e4 application?
FXViewPart only makes sense in an Compat-e4 application.
On FXCanvas:
So did you added a package import for javafx.embedd.swt? Did you try
lauching with -Defxclipse.osgi.hook.debug=true to see if the adapter
hook is loaded?
On usage in pure e4+SWT:
In case you have a pure e4 application simply:
a) add
- org.eclipse.fx.ui.di.interopt
- org.eclipse.fx.osgi
to your launch config
b) launch the application with -Defxclipse.osgi.hook.debug=true
c) Simply develop a pure JavaFX Part like this
public class TestFX {
@PostConstruct
public void init(BorderPane p) {
// write your javafx code
I would suggest to have the parts who are implemented in javafx in
an extra bundle which has NO swt dependency but only does package
imports for javafx!
Tom
Tom
> application.
> platform.
> org.eclipse.rcp
> Based on https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial2, I added
> @Override
> @Override
> found.
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1411139 is a reply to message #1411138] |
Fri, 22 August 2014 13:43 |
one more note. On Linux JavaFX will only be loaded if your SWT is
running with Gtk2, JavaFX fails when SWT runs on Gtk3
-Defxclipse.osgi.hook.debug=true will spit out informations if this is
the case.
You need to force SWT to Gtk2 by setting SWT_GTK3=0 in your env.
Tom
On 22.08.14 15:41, Tom Schindl wrote:
> On FXViewPart:
> On FXCanvas:
> hook is loaded?
> a) add
> @PostConstruct
> imports for javafx!
> Tom
> Tom
>> application.
>> platform.
>> org.eclipse.rcp
>> @Override
>> @Override
>> found.
Re: Embedding JavaFX in SWT E4 RCP application doesn't work [message #1412167 is a reply to message #1411138] |
Mon, 25 August 2014 13:07 |
Thanks for your hints, I found the root of the problem in the meantime:
Bundle-RequiredExecutionEnvironment in the manifest file was set to JavaSE-1.7. Only after setting it to JavaSE-1.8, jfxswt.jar has been added automatically to the application plug-in dependencies. This allowed me to finally use FXCanvas:
@PostConstruct
public void createControls(Composite parent) {
final FXCanvas fxCanvas = new FXCanvas(parent, SWT.NONE) {
public Point computeSize(int wHint, int hHint, boolean changed) {
getScene().getWindow().sizeToScene();
int width = (int) getScene().getWidth();
int height = (int) getScene().getHeight();
return new Point(width, height);
javafx.scene.Group group = new javafx.scene.Group();
final javafx.scene.control.Button jfxButton = new javafx.scene.control.Button("JFX Button");
jfxButton.setStyle("-fx-background-color: linear-gradient(#ff5400, #be1d00); " + "-fx-background-radius: 30; " + "-fx-background-insets: 0; " + "-fx-text-fill: white;");
group.getChildren().add(jfxButton);
Scene scene = new Scene(group, Color.rgb(parent.getBackground().getRed(), parent.getBackground().getGreen(), parent.getBackground().getBlue()));
fxCanvas.setScene(scene);
I'll comment on your reply in case other people with similar problems find this thread.
Quote:First of all is the application you develop a pure e4 application?
Yes, it's pure E4. That's why I asked about the usefulness of FXViewPart in this case. Thanks for the clarification, now I don't need to worry that this still doesn't work.
Quote:So did you added a package import for javafx.embedd.swt?
It was imported via the org.eclipse.fx.javafx plug-in, so I couldn't even add it to the Imported Packages list.
hook is loaded?
I had tried launching with that VM argument before, but it didn't have any effect on the output. Now there are indeed messages from FXClassLoader etc.
org.eclipse.fx.osgi seems to be a fragment which I couldn't add to the dependencies. org.eclipse.fx.ui.di.interopt was not needed to make my FXCanvas example run.
@PostConstruct
imports for javafx!
Thanks, these are useful hints for future development of the application.
Quote:You need to force SWT to Gtk2 by setting SWT_GTK3=0 in your env.
Good comment, I have to do this anyway for Eclipse Luna because otherwise the whole IDE wouldn't even start.
Current Time: Fri Apr 26 16:49:35 GMT 2024
Powered by FUDForum. Page generated in 0.03203 seconds
