Home » Eclipse Projects » Mylyn » Trying to manually install mylyn using copy&paste for Ubuntu eclipse luna
Trying to manually install mylyn using copy&paste for Ubuntu eclipse luna [message #1410808] Thu, 21 August 2014 13:14 Go to next message
I have recently installed e(fx)clipse all-in-one package for Ubuntu. After installation, I have the task list window error, so I check the AinO package and it seems that it totally miss the Mylyn plug-ins.
So I have downloaded "mylyn-3.12.0.v20140609-1648.zip" file. And I'm planning to just copy and paste everything inside there to the installed eclipse folder. Laughing
Would this work?
I'm quite possitive that everythings in the features folder and the plugins folders should go to /opt/eclipse/features & /opt/eclipse/plugins.
But I'm not sure where to put the artifacts.jar, content.jar, site.xml.
Should I just put them /opt/eclipse/ ?
And also wonder there would be any config files to edit a line or so.
Thanks Razz
Re: Trying to manually install mylyn using copy&paste for Ubuntu eclipse luna [message #1410829 is a reply to message #1410808] Thu, 21 August 2014 14:39 Go to previous messageGo to next message
Instead of trying to do that, I recommend just installing from the update site: Help > Install New Software > Work With: http://download.eclipse.org/mylyn/releases/latest
If you can't connect to the internet from that environment, you could add the zip file as an archive site and install from there.
Sam
Re: Trying to manually install mylyn using copy&paste for Ubuntu eclipse luna [message #1410956 is a reply to message #1410829] Thu, 21 August 2014 23:21 Go to previous message
I installed the Mylyn using Help>Install New... and it works perfect Smile
Thank you for your answer.
Yongshin
Previous Topic:github connector and problems with labels and other attributes
Next Topic:Mylyn Reviews without Git/Gerrit
Current Time: Wed Sep 24 12:15:16 EDT 2025
Powered by FUDForum. Page generated in 0.06957 seconds
