Home » Eclipse Projects » Sirius » Unable to create view point selection(Unable to create view point selection)
Unable to create view point selection [message #1410287] Wed, 20 August 2014 06:10 Go to next message
Hi All,
I have some questions,
Firstly does sirius support xtext integration?
Secondly I have an existing ecore but dont have editor and edit plugins. Does sirius can be used to create one.
Thirdly : I followed the entire tutorial step by step but when tried to add viewpoint Selection. The dialog was empty.
I also downloaded the examples from sirius site. even those does not work
Girish
Re: Unable to create view point selection [message #1410633 is a reply to message #1410287] Thu, 21 August 2014 04:53 Go to previous messageGo to next message
Le 20/08/2014 12:10, Girish Kumar a écrit :
> Hi All,
Yes, there are other posts on this forum about that ([1] for example).
Not really. Sirius allows you to create a Viewpoint Specification
Project that contains all is needed to generate editor and edit plugins.
But it is always EMF (with genmodel file) that generates the editor and
edit plugin.
I do not have enough information to help you. If the viewpoint selection
dialog is empty, you have probably no file with the expected extension
(defined in your odeisgn file) in your modeling project.
> Regards
> Girish
[1]
https://www.eclipse.org/forums/index.php/mv/msg/610671/1201144/#msg_1201144
Laurent - Obeo
Need professional services for Sirius?
Re: Unable to create view point selection [message #1414206 is a reply to message #1410287] Sat, 30 August 2014 12:08 Go to previous messageGo to next message
Same Problem to me
eclipse-luna with sirius (Eclipse Modelling Project) V 1.0.0.201406040902
if i create new /Sirius/ModelingProject
under Modelling View
empty project with:
- ProjectDependencies
- representations.aird
is created,
if i right click project /ViewPoints Selection
it's always empty !
i have one small testproject where this was working, but i don't know how i can configure it to get it running
perhaps somebody can help me
Re: Unable to create view point selection [message #1414750 is a reply to message #1414206] Mon, 01 September 2014 04:01 Go to previous messageGo to next message
Hi Horst,
the Viewpoints shown in the Viewpoint Selection dialog are computed from
all the model files located under the modeling Project. For instance, if
you have an ecore file then the dialog will show all Viewpoints that are
defined on ecore models.
So if you do not have any model file in your Modeling Project, no
Viewpoint will be displayed.
Please let me know if you have further questions.
Alex
Le 31/08/2014 17:38, Horst Leitenmueller a écrit :
> Same Problem to me
> empty project with:
> - ProjectDependencies - representations.aird
> is created,
> it's always empty !
Alex Lagarde - Obeo
http://www.obeodesigner.com/sirius/
Re: Unable to create view point selection [message #1422986 is a reply to message #1414750] Sat, 13 September 2014 14:51 Go to previous messageGo to next message
Try this tutorial :
alain-bernard.developpez.com/tutoriels/eclipse/sirius-intro/
It is in french.
You have only to change on page 11 the Extension File Name ("odesign") by "airports" which is the extension name of the model you want to display.
Ph Revellat
icon9.gif  Re: Unable to create view point selection [message #1695280 is a reply to message #1422986] Wed, 13 May 2015 05:46 Go to previous messageGo to next message
Hi ,
I am experiencing the same problem with sirius. When i open the viewpoint selection i have an empty list. I followed two tutorials , one in developpez.com and the other in eclipse website. but i can't achieve good results Sad !
Please can help me Smile
Re: Unable to create view point selection [message #1695450 is a reply to message #1695280] Thu, 14 May 2015 14:20 Go to previous message
Try adding the ecore model under the Project Dependencies > Add model
Previous Topic:Empty diagram
Next Topic:How to access a view variable in the Precondition context?
Current Time: Wed Jun 25 02:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.14900 seconds
